Lobo Off-Road
Hemet, CA
lobooffroad.com
All of them
https://lobooffroad.com/product/rear-lca-frame-skid-kit-bronco/
Ford Bronco Lobo Off-Road Rear LCA Frame Skids F6-57-4410_F-2400
Protect your Bronco's undercarriage from trail damage with these Rear LCA Frame Skids from Lobo Off-Road. The rear suspension lower control arms attach to the Bronco's frame close to it's center break-over point and hang down below the frame rails, making them an easy target for high rocks and ledges on the trail. The skid has a ramp profile front face to help move the Bronco up and over rocks rather than hanging up on them.
Ford Bronco Lobo Off-Road Rear LCA Frame Skids F6-57-4410_A-2400
The components are CNC laser cut from 3/16" plate steel or aluminum, brake-formed and fixture-welded for a perfect fit. Available in steel with black powder coat, and in aluminum either raw or with black powder coat.
PLEASE NOTE the aluminum skids are not as strong as our steel skids. They will provide protection to your frame components but may themselves bend if taking a hard enough hit under severe rock-crawling conditions. That said, they will provide ample protection for most use-cases, will not rust when scratched or gouged, and are about a third the weight of steel.
Check them out on our website at https://lobooffroad.com/product/rear-lca-frame-skid-kit-bronco/ and please let me know if you have any questions.
Also in case you missed it, we are now offering FREE SHIPPING to the Lower 48 United States!
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Do they accommodate Hoss 3.0 suspension? (BadSas MY25)
Why wouldn't they? The OEM lower control/trailing arm(s) are the same on every Bronco regardless of HOSS 1/2/3 suspension. Note: I'm unsure if the Raptor LCAs are different and I suspect they are.
HOSSMAN
HOSS
Boerne "Burn-E", TX.
'23 Badlands '24 IS 350 F-Sport '26 150 Tremor
Cool! Do you offer (or are you going to offer, didn't see on your site) front LCA skids?
Thinking of ordering, any chance on a custom powder color...orange? Trying to keep up with my theme.
Ford Bronco Lobo Off-Road Rear LCA Frame Skids Bronky Rear 2026
Mean Green
Bill
Warminster, PA
23 Ford Bronco 2dr Badlands Sasquatch
Any install videos yet?
decummins
Daniel
New Hampshire
2022 Bronco Wildtrak
I have a 22 and a 24 wildtrak. (Hoss 2.0 v Hoss 3.0). The 24 bronco has reinforced plating welded to the LCA at the frame. This is a difference.
Dusty
Mentone, CA
70, 71 & '21 Broncos
Nice looking kit Chris! I' might have to pick up a pair of those and shoehorn them onto my already-beat-up frame mounts.
Lobo Off-Road
Lobo Off-Road
Hemet, CA
lobooffroad.com
All of them
We offer the aluminum ones raw that you can have powdercoated. Unfortunately I do not have the bandwidth to offer custom colors at this time.
ironmike
2022 Bronco Raptor
They are indeed different.
Lobo has yet to produce any BRaptor products….
crenca
Southern New Mexico
The kit was prototyped off of Our 22 wild track shop bronco, that is equipped with a hoss 3.0 option.
I'm not absolutely certain but I don't believe it's a hoss 2.0 or 3.0 issue, rather a model year issue because that is what determines if the reinforced plating from the factory is present or not.
If Lobo only tested their skid on a non-reinforced Bronco, then it's open question whether it fits on a later year Bronco so equipped....
0ne
Nate
CO
Flex
no install video yet. Hope to have an Install video and instruction sheet soon.
Is passenger side a pita to install due to gas tank?
