TeocaliMG
Plymouth Michigan
Hey Guys, if you're running 37's or bigger, you have probably realized that the OEM fender flares do not clear larger tires properly. You can daily drive just fine, but if you do anything beyond light off-roading you need to remove them. Before doing this trim, I had damaged both front flares 2 or 3 times each. If the tire made contact too aggressively it would pop the outer (visible) portion of the flare (partially) off of the inner reinforcement structure (plastic spot welds). I had to clean/prep/reglue them together in multiple times.
There are options to address this out there already (since basically day 1), anything from simple deletes all the way up to totally different fiberglass quarter panels.
If you're like me and you either like the OEM look, or are cheap (or both) then you may consider trimming them like I have. I highly doubt I'm the first to do this, but I hadn't seen it posted so I wanted to share my DIY method.
Here is the finished product: With this clearance I am able to wheel at about 100% travel (flex, not jumps) without needing to remove the flares.
Ford Bronco DIY High Clearance Flares 1756060253141-ya
Before and after: Note the front left fender was the most recent to detach, leading to my decision to go ahead with a trim. To reattach the flare this time around I opted to use a couple 3D printed rivets I could melt in place rather than trying to re-glue the clamshells back together again. (only front portion was detached)
Ford Bronco DIY High Clearance Flares 1756060634308-ya
Ford Bronco DIY High Clearance Flares 1756061338354-v4
I used a router with a small diameter bit to do the rough cut trim. I'm sure you could use a number of different tools, but I felt this was my best shot for getting a controlled cut that would follow the exact profile I wanted. (Left after rough cut, right after sanding)
Ford Bronco DIY High Clearance Flares 1756061109393-hc
Ford Bronco DIY High Clearance Flares 1756060783481-nr
I followed the natural line of the "skirt" portion of the flare that hangs down below the inner reinforcement structure. This "skirt" zone also has about half of the plastic weld zones so that needed to be addressed later. Overall this portion is about 3/4" of an inch.
Ford Bronco DIY High Clearance Flares 1756061194120-d1
Ford Bronco DIY High Clearance Flares 1756061680074-yq
The rear fenders have a couple spots where the "skirt" zone is interrupted by a half circle extrusion. I opted to just plow right through that and remove it along the same arc. Shown before and after sanding:
Ford Bronco DIY High Clearance Flares 1756061561697-60
Ford Bronco DIY High Clearance Flares 1756061609931-ko
It is hard to see in any of my photos, but after the rough cut and sanding, I went over the seam between the outer flare and inner substructure with a plastic iron to "weld" the two surfaces together. This was to make up for the lack of several key structural connections that were cut off.
Ford Bronco DIY High Clearance Flares 1756061812273-e1
Overall I cant believe I waited until nearly 4 years of ownership to make this modification! Its super functional, and honestly I prefer the unique look!
The benefit is twofold as well, there's the obvious 3/4" increase in tire clearance, but less obvious is the reduction in stiffness. Without that side skirt on the flare, it is much more flexible, which means if my tire does make contact, it is more prone to deflection rather than failure.
TeocaliMG
TeocaliMG
Plymouth Michigan
A 3" body lift solves this.
TBH this is less work than a 3" body lift with none of the downsides (and sure, only one of the benefits)
Valhalla
Valhalla
Chattanooga Tn
I've had a 3" since early 2023,,, no downside here and pretty easy.
Valhalla
Valhalla
Chattanooga Tn
Edit, you may need this for a non=squatch
TeocaliMG
TeocaliMG
Plymouth Michigan
I started with a non-squatch badlands (manual), so that's indeed correct. But now I am on Icons, but it remains correct for that as well.
Valhalla
Valhalla
Chattanooga Tn
meh, going to 40's soon hopefully, i'll use 1" suspension with my 3" bodylift... keeping it low with the lift.. this does also...
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
Did you freehand the router cut?
TeocaliMG
TeocaliMG
Plymouth Michigan
I held the fender by hand but was tracing the line pointed out above. If I had to trace an arc with no visual guide it would have come out pretty ugly. I trimmed just shy of the skirt line and then used the flappy disk to smooth it all down right to that level.
TeocaliMG
TeocaliMG
Plymouth Michigan
Brokenparts
Zach
Hillsboro, OR
1966 FJ45, 73 c-10, 79 Blazer, '23 Exp, 2008 F350,
Excellent work. Summer is coming to an end, and I need to remove the fender "deletes" and add back my OEM fenders. This makes it possible with my 37s. Looks good and is functional, that in my book, is always the best scenario when modifying parts.
TeocaliMG
TeocaliMG
Plymouth Michigan
Indeed! Just cut nice and slow and cut in the direction that the router will pull away from the fender and not into it to minimize the consequences of inevitable errors (as me how I know lol)
Brokenparts
Zach
Hillsboro, OR
I plan on using my bandsaw or my body panel saw for this, unless you see an issue cutting the fender material with a saw (melting issues, balling, flex/stress issues, etc) .?
TeocaliMG
TeocaliMG
Plymouth Michigan
That should work fine. there might be some balling, but you just let off, let it cool and keep going. As long as you have clearance to swing the fender around in the air you should be fine.
Amazon.com: Mini Iron, 80W Tiny Iron for Small Crafts Patches Clothes Shoes Hats, Adjustable Temperature, Easy to Use, with Replaceable Iron Tips (Black) : Home & Kitchen
This is what I used for the finishing touch after sanding, to melt to two surfaces back together. Around the 250-300C range. (Bought for another project, but has come in handy for several plastic related projects already)
