High Clearance Intrusion Beams by Massive Speed System!
Caleb@PandaMotorworks
Caleb
St Louis MO
  • Gain Tire Clearance Without Compromising Safety
  • Additional Tire Clearance: 1.7" in Front and 1.2" in Rear
  • Prevents Moisture and Debris From Gaining Access to Vehicle's Frame
  • 6061 Billet Aluminum Construction
  • High Strength Grade 10.9 Zinc and Yellow Plated Hardware Included
  • Anodized Finish Available in 5 Colors
Going with big tires on your new full-size Bronco? You will promptly realize you're going to run into your stock intrusion beams. These steel tubular pieces are designed as a collision safety feature, however, they interfere with larger than OEM tires, particularly near full lock turning. Thankfully, these beams simply bolt on to the chassis and can be easily replaced.
While gaining this much-needed clearance was crucial, we didn't want to sacrifice integrity, so we machined these ones from a solid block of 6061 Aluminum - lightweight and STRONG! They also won't rust like a steel one WILL. Their solid nature also impedes moisture and salt from gaining access to the inside of the vehicle's frame, unlike stock or other aftermarket versions.
Adds some visual appeal, available in your choice of anodized colors. Made in-house right here in the USA! Includes high-strength grade 10.9 Zinc and Yellow plated hardware in case your factory stuff is destroyed from road salt or serious wheeling! Due to the placement of this part, it is inherent that it will be struck by all manner of road / off-road debris. Therefore, the finish should be expected to wear over time.
Ford Bronco High Clearance Intrusion Beams by Massive Speed System! DSC06597-4_960x658
Ford Bronco High Clearance Intrusion Beams by Massive Speed System! DSC06631_960x875
Ford Bronco High Clearance Intrusion Beams by Massive Speed System! BroncoIntrusionBeamsPurpleV3_960x613
EasternSierra
Bill
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
