Fordified1
Bob
Mid South Texas
ā€˜15 Mustang ecoboost, 4wd Excursion, ā€˜69 Mach 1
I was a knucklehead today and forgot to lock the rear diff. Got in a bind close to the edge and hammered it enough to knock teeth off the front ring and pinion (190 with no locker). When I figured my brain fart and locked the rear diff it walked right out of the bad spot I had gotten it into. Both embarrassing and expensive. Limped it to a buddies shop and we had the diff out and tore apart in about an hour to see the damage.
Don’t be too hard on me. Hopefully someone can learn from my mistake.
Ford Bronco Rear locker can save a front diff. IMG_8395
Ford Bronco Rear locker can save a front diff. IMG_3091
SierraBronco
Dangit. Time for an upgrade! Can you add a locker to M190 with the factory gearing or do you need to replace front and rear? Pretty annoying that you can get the UFDU in 4.70, but not the D60.
If you want a recommendation on an axle shop let me know.
Fordified1
Fordified1
Bob
Mid South Texas
Thanks. We’ll have it running by tomorrow evening hopefully, I didn’t have time to wait for the upgrade parts because we’re getting ready to go on vacation with the Bronco. Already located a local takeout from a low mileage ā€˜24 cheap. (I’ll be more specific when the deal is done)
Techun
Pa
BD, 2.7, MIC, 4dr
Dang, that didn't look that extreme :/
Fordified1
Fordified1
Bob
Mid South Texas
I know right? An M190 diff is super weak because of the shallow tooth depth and thin ring gear which deflects easily. But if we had just stopped and winched like I asked my spotter to do, it wouldn’t have broke. Or of course with the rear locker engaged I wouldn’t have gotten in that predicament in the first place and felt the need to hammer it.
GI_Jo_Nathan
Jonathan
Sorry that sucks.
This is why I preemptively use at least my rear locker on certain obstacles. The internet has people so scared to use them, or thinking of them as a last resort. But it's a tool that can save damage.
On another note recognize this trail at Hidden Falls. Great park!
Glad y'all have access to a place to work on it. I was over 700 miles from home when I visited.
SierraBronco
Sorry that sucks.
This is why I preemptively use at lead my reatlickern certain obstacles. Yes internet has people so scared to use them, or thinking of them as a last resort. But it's a tool that can save damage.
There are definitely times where only using the front locker can be beneficial as well. Nice that Ford gave us that option for front OR rear, and not just front AND rear.
orion
Jeremy
17' F-250, 17' Explorer
Sorry that sucks.
What you trying to say here, 🤣
GI_Jo_Nathan
Jonathan
SierraBronco
Lmao
Reading that gave me Forrest Whitiker eye the first few times but then it hit me that it was about using the locker 🤣
NC_Oak
2024 4 door 2.3 sasq
I use my rear pretty much every time I'm out at least once. As gi jo stated, I also preemptively lock the rear on some sections I know it will help or be needed.
Sucks you broke the front diff, lesson learned and good of you to share. Glad to see the trolls didn't lay into you. Your spotter tho, "roll through it". :wink:
vrtical
Doug AI
GSMNP, TN
Fords
Honestly I mostly run with my rear locker engaged and only use my front when absolute necessary and/or I know I don't need any / zero steering input. if its that complicated, use the winch, its cheaper and wont get stranded. Yeah the front only locker is a thing, just not sure on this 6G.
