malicious1
Kevin
College Station, TX
2022 Bronco Badlands 7MT
I figured now that everything is mounted up I would share my "super-budget" on-board compressor solution. There is no doubt that this solution is fraught with safety questions but it has proven an inexpensive solution for my priorities:
  1. On-board hardwired compressor
  2. Compressor mounted in cargo area but not affecting the storage space
  3. Sub 10-minute air-up from 20psi to 36psi with a 4-tire inflator
My one required previous mod was mounting an amp behind the right rear cargo side panel. This brought a 4ga power wire to that back right side which made it possible to hardwire my compressor with sufficient amperage.
Here is what I did. I picked up the Samout 7.06CFM single compressor with LCD control panel and Preset target pressure on sale from Amazon for $100 and a Rough Country Side Window Molle Panel Kit for $80 on an open-box Amazon deal. I realized the Samout compressor is a square body so I remounted the "foot" to the back instead of the bottom. There were some fins I had to make some small relief cuts to get around. I matched up the hole pattern in the molle and drilled mounts in the stock foot plate. Using a 50amp inline breaker (Amazon $11) I connected the compressor cord to my 4ga amp power cable and grounded to a body lug. The molle panel is designed for the hard top but since I have the SSV speaker box on the driver's side I was able to cut that mounting plate up so it would mount to soft-top bracket. This molle panel compressor solution now works with both my soft top and my hard top.
Testing from 20-36psi with a 4 tire inflator ($61 Amazon) was 7min and 30sec. The compressor head was still cool enough to touch but the 4 way gang was pretty spicy.
@ThinBlueBronco and I tested it on the trail with a 40amp breaker and it tripped a few times. The Samout is rated for 45amp so it must use most of that even at lower pressures so I change to 50amp and haven't had any further issues.
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250406_212659548_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250406_212716742_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250406_212758336_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250406_212810886_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250406_212838609_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250406_214450900_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250406_212741031_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250315_184237732_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250315_185903477_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250315_184319579_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250315_203438785_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250315_203846292_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250315_200636470_iOS
Ford Bronco On-board auto-stop air compressor $200 - DIY setup 20250315_202528185_iOS
buzpro
Binky
Tacoma
I figured now that everything is mounted up I would share my "super-budget" on-board compressor solution. There is no doubt that this solution is fraught with safety questions but it has proven an expensive solution for my priorities:
What a great idea!!! Absolutely love it. I'm gonna be your first copy cat with my comp but i will have to do it in a way to have a quick release on the platform. I don't want it installed 24/7.
GREAT JOB MAN.
malicious1
malicious1
Kevin
College Station, TX
Honestly if you put a 50amp quick disconnect in the middle of the cable, you only have to zip off those 4 Nylon nuts and it's out. If you mark the holes in the Molle you could put anything else up there normally and then just swap out for the compressor.
Ninjak
Miami
That's a hell of a setup. Great job. Question on your SUB? How is that working out? I am thinking of upgrading, and I am looking at that as I want to do the Alpine setup, Bass and AMP from Trail Seven. I can put that sub together myself.
malicious1
malicious1
Kevin
College Station, TX
I love the Alpine 10" with the SSV Works enclosure. It is really boomy. You do have to work around it in the cargo area but I swap tops as the seasons change so it's really not that bad (it works great with both). With the Alpine A55 and the LC5i-Pro behind the cargo panel there was no space for a sub. I didn't want the weight or to use space on the tailgate and I didn't want it on the floor of the cargo area.
malicious1
malicious1
Kevin
College Station, TX
The 40amp tripped reliably at 40amps draw, I haven't put the multimeter on the 50amp and it is nice to have a manual physical disconnect button. I leave disconnected all the time and only reset the breaker when I am using the compressor. (Kinda more like a switch than a breaker)
adam1991
VW GTI (2)
I'm thinking more of it being a cheap piece from Amazon. But yeah, leave it disconnected and it's passing current only while you're using and watching it.
malicious1
malicious1
Kevin
College Station, TX
Yes, Amazon quality should be suspect and I agree it is only reset when running and then manually tripped to isolate it the remainder of the time.
wgw
bill
Va
2023 Black Diamond Bronco
Very neat and clean…nice work sir
George
2023 Bronco OB Squatch
Good idea about the quick disconnect, as I also wouldn't want to keep it mounted 24/7. I just don't wheel enough to warrant a permanent mount, but a semi-permanent mount for trips is very appealing.
Thanks for sharing your work! Well done!
