Best on-board air compressor mount
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I'd definitely be curious to what they say, they even called me to tell me it shipped (which was kinda awesome, don't see that much anymore) and I mentioned to them I had their quad already and loved it for my Tacoma. I told them I am going to try to perm mount it in the engine bay of the Bronco and he said he would love to see pictures if I can make it work. 🤷‍♂️
I just emailed him to get their feedback. Because portable compressors are not designed to be ran under hoods or in environments like that. There's a lot of water/crap that gets thrown around in the engine bay and portable air compressors are not as sealed as an on-board one. Even the ViAIR air compressors have PORTABLE versions and then ONBOARD versions for a reason.
Just don't want to see you go through all that work to ruin an air compressor's life expectancy.
cynicalrider
NJ
First gen taco
Absolutely and I appreciate it too. That was definitely a concern especially with the fancy autoset controls. If they do come back saying it should be good I think the grimm offroad mount will get me 90% there, but this compressor is almost 4" longer than the ARB dual and mounts differently so I would essentially need to remake the "cage" they wrap around the compressor but other than that it looks like it should fit.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
My rep just emailed me back and told me he does not recommend putting their portable air compressor in the engine bay.
No the grimm mount will NOT work, even if you wanted to tackle it. None of the compressor brackets on the market will work with a portable air compressor. They are all designed to work with a Twin compressor.
Since we have a patent pending design on our mount Grimm mounts the ARB compressor different then we do, vertically (similar to what SDHQ does). There is no way you can utilize that to mount a portable air compressor, it won't even fit in the opening.
And the portable compressors are too big to mount on ours. The ARB twin doesn't sit that high don't forget, so the hood can close. But your portable (and most portables) sit higher up.
cynicalrider
NJ
First gen taco
Yeah I already stated that I would essentially need to remake the cage to accommodate the extra length. I'd also need to create a bottom that mounted in between the cage that the compressor would sit on and essentially mount to. When mounted vertically I measured that i would have at least 2-3" of space between the compressor top and the hood. The only thing that would be reused on the Grimm mount would be the mounting points in the engine bay.
I had no idea SDHQ also had a vertical mount. That would actually take far less re-fabrication to mount this compressor now that I looked at that design. I'd only need to weld a bottom to it to mount the compressor to that would be more than strong enough.
That's a bummer about what your rep said though, I will reach out to who told me it can be mounted under the hood and see why mixed information is being delivered to customers.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Why not just get our KR Off-Road Kit w/ARB Compressor. You save 10% on the entire kit and it's an onboard solution.
Portable air compressors are meant to be that, portable, not mounted to something.
cynicalrider
NJ
First gen taco
Mostly because the ARB is twice the price, half the speed, and doesn't have the features the Morrflate has when combined with their hose. And I literally already have the compressor.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
The ARB isn't half the speed. where did you get that info from?
cynicalrider
NJ
First gen taco
"This beast will take care of all of your portable off road air needs. Twice as fast as Smittybilt 2781s, and 58% faster than a Twin ARB! The big story that makes the TenSix™ shine, is what happens when you combine it with a MORRFlate 4 Tire Kit™:"
https://morrflate.com/shop/air-sources/portable-compressors/morrflate-tensix-psi-pro-12v-compressor/
But of course manufacturer sites can be potentially incorrect or based on theoretical numbers, I would love to do a real world test on the same set of tires comparing the two with the same setup. I have several buddies with ARB Twins so I might do it for science. 🤓
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I mean I could do one today. I have a TenSix sitting here :)
cynicalrider
NJ
First gen taco
I'd be curious for sure. This video makes it seem like they are comparable in speed, they cut off before it actually hit 35 psi but my test was super similar. 15 psi to 35 psi on stock 35's.
So maybe same speed?
cr117
PNW
Bronco, EV6
This test shows quite a disparity:
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We just tested this on our own truck
37x13.50 Tires
15 PSI to 35 PSI
MORRFlate TenSix: 1 minute, 40 seconds
ARB Twin: 1 minute, 40 seconds
Soooo they air up in the same time.
The drawback to the MORRFlate TenSix is that they DO want you to use a multi-tire inflation kit, so that the back pressure from a single tire does not damage the compressor.
The positive is that it's portable, cheaper and you can pre-set a PSI. The compressor turns off every so often to read the pressure.
The downside is that is does take up some space as it's pretty large.
The upside to the ARB Twin under the hood is that it's ready to go and out of the way.
Downside is the price of course. It's a BIT more then the Portables.
cynicalrider
NJ
First gen taco
I was scrubbing the video but wasn't sure if he said the tires on the rigs are exactly the same size?
37x13.50 Tires
15 PSI to 35 PSI
Single tire test? But agree the not being able to use it 1 tire at a time thing does suck if for some reason your quad kit failed on you. Basically will need the compressor to cool off and rest a bit between tires to not damage it. Lots of great discussion in here comparing the two.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
My twin ARB inflates each of my tires in less than a minute. NO portable inflator does that.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah I did the same. I know the 2nd truck (not his) had 38" tires. But Im not sure what size HIS tires were. If he has 33" tires for example that's a big difference.
I only did one single tire at a time. I guess maybe when we're slow i'll try with the multi-tire kit. It takes time to air down my 37's though which is why I ony did the 1 tire.
Although with the Staun Tire deflators I use, i don't have to monitor it.
