Worst build thread EVER.
G1D1UP
J.
Gilbert, AZ
2024 Ford Bronco Raptor
Ford Bronco Worst build thread EVER. pngtree-fat-lazy-guy-watching-the-tv-weight-obese-couch-photo-picture-image_4050295
Sometimes, after watching the cardio channel, I often wonder why Bronco owners don't wave? What are your thoughts about waving? Pretty sure it's never been discussed here.
Also, how do you feel about people putting small ducks or bucking broncos on your rig? I wish forum members talked about serious, compelling issues like this more often on these forum threads....
Ford Bronco Worst build thread EVER. 1473162742-iron-man-tony-stark-marvel-eye-roll
ducksface
ducksface
Stroppe
Grand Canyon, Arizona
2025 stroppe
Stroppe
I've been running 30psi in tires.
No problems.
Today, during a rain storm, the dash and app decided this was low pressure and posted a warning. 700 miles without a warning...now a warning.
Did we have a recent update that might have changed the parameters?
And
Will forscan let me change the low limits?
When offroad and aired down do you just ignore it or do different modes ignore it?
ducksface
ducksface
Stroppe
2025 stroppe
Stroppe
No problems.
And
If you look at Ford Pass, it shows your "Suggested" tire pressure. You can adjust this number in Forscan. (It should match your placard on the door jam if you have it all OEM)
Low tire pressure triggers at 15% under that target number. Likely you were riding on the border of it triggering, and the rain lowered the temp/pressure just enough to trip the light. You have to get it back ~over~ the suggested pressure for the light to clear.
Couple of ways about it:
The easiest /safest way is to just ignore it when off roading and lowering tire pressure.
Or you can adjust it in Forscan, but I'd recommend not adjusting it so low that you might throw a tire on the freeway if you do have a slow leak creep up on you.
ducksface
ducksface
Stroppe
2025 stroppe
Stroppe
I often experiment. The $100 was worth the risk.
I've bought from zero folks on ebay.
I'm wild that way.
Last week I opened the microwave before it beeped.
I am
Ab
So
Lute
Ly
Wild.
I am not an ai fan by any stretch.
But it said pretty much what I knew.
When I saw what app it used and the button locations I figured I was safe enough.
I just bought similar for the pacifica. Same app, different company name.
I'll post some pic clips tomorrow.
ducksface
ducksface
Stroppe
2025 stroppe
Stroppe
Side step;
I have a dash cam suctioned to the rear window of the bronco and the pacifica.
I didn't want to run the wiring for a front/rear combo and the rear one is independent(one is none).
As I replace older cameras with rear view mirror or these hidden type, I'm getting a drawer full of the older suction cup and screen units.
I'll slap them in side windows when I run out of rear windows.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
yeah AI is just regurgitating what it read on their website since that is the only place the word "FUVYMYT” exists.
Definitely a plus if it works with an app you already use.
Appalachia_Ewok
J
Tennessee
'02 PT Cruiser, '62 DeVille, '96 XJ, '23 Bronco
This is called a
Cheese plate.
0/10 don't recommend. My driving cheese fell right off into the floor.
What's everyone's preferred driving cheese?
I like cheddar with parmesan notes. The robust taste of cheddar embodies the rugged Brocno, and the mouth feel of the parmesan reminds me of the fine gravel dust in my mouth after cruising forest roads with the top down.
