Windshield washer reservoir capacity
filup01
ā€˜21 F-150
It sounds like you extended your rear wiper hose, ran it to your seat, and filled your wiper reservoir with a tasty alcoholic beverage.
Climber_Diver
Climber_Diver
Rick
Escape
I guess it depends on how long you run the washer for you half dozen times.
Barring that, you have already troubleshooted a leak, so that leaves intermittent pump failure (which I assume you hear the pump running, just no fluid coming out), or other reservoir issue (maybe the bottom is filled with sand or jello). When you run out of fluid, how much fluid does it take to refill?
I’ll have to check if I hear the pump when I’m not getting fluid. I can only add a quarter of a gallon when I refill and I can’t see the entire reservoir which is why I asked about the capacity.
AKBronc49
Russ
Anchorage, Alaska
I've put about 2 gallons in mine over 2,400 miles, given the weather and road conditions its the same as I put in my other vehicles.
SVTLightning
Christian
Canada
Titan
Do you just fill up whenever you feel like it? Or is your low level light on when you fill it?
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
Ford Bronco Windshield washer reservoir capacity IMG_1013
Speaking of washer-fluid, does the Bronco have auto-detect rain sensors?? This is from the 2022 Bronco manual (page 92).
DefNotBuddyLee
Austin
Mustang / Jeep / F150
Looking at the shape of the reservoir, it appears to be hourglass. I am wondering if you have an obstruction in the middle giving you only half capacity. If it were an older car, I would say mice or bees for sure to make your life crazy. :p
Does your washer fluid smell like honey or wet mouse? Best way to check is by taste.
Ford Bronco Windshield washer reservoir capacity reservoir
level3looper
New York
Strange.
I was psyched when a full gallon fit. It always annoyed me on all my VWs when a fraction of the bottle had to get stashed for next time. Liters? Ha!
Sounds like some sort of pump issue?
I've had a bunch of different cars, including jeep, and this is the first one that takes the entire bottle. It seems like it could take more as well.
Silver-Bolt
Eureka, MT
Someone report here that the hose to the rear wiper was disconnected under the carpet. Any wet carpet issues? Is it really empty or maybe a pinched hose?
