Plugging Front camera washer hose?
GreenMtnBronco
West Nyack NY & Central VT
'21 BadSquatch; 04 Lifted Mini
I seem to go through washer fluid incredibly fast. When in for an oil change I had my shop look at it and they reported that its functioning fine, but that a lot of fluid comes out of the front camera washer. I personally don't care about that and can wipe it off when needed, I assume this is for the trail cam and not the anti collision or parking sensors.
anyone else plug theirs upor have a suggestion on parts/ how to?
thanks
615_Bronco
Cheatham, TN
2022 Bronco 2D BL, SAS, MT, & 2015 F-350 DRW
Did you relocated it or is it in the stock position?
BigMeatsBronco
Allan
2021 FE 2 door
Behind the grill, in front of the the air cleaner, there is a connection you could unplug...It is the same style as the rear window wiper connector. You could plug it there, Or on the passenger side, above the fender liner, there are a couple of "T" connectors, that you could eliminate and swap in a straight through version instead, deleting the camera hose.
Brostango
Bay Area, CA
2005 F150 Crew, 2016 ATS Coupe
i might be mistaken but i think there is a check valve right before the camera nozzle. Might be worth checking.
Brostango
Bay Area, CA
you can access this by removing the top plate that the hood prop rod secures to and the griile
Bschurr
NY
You are correct - similar to the rear, when you disconnect the hose at the connection with the button, fluid will cease to flow past that joint. 👍🏼
