Windshield rock chip/crack. Repair or replace?
themendoza001
TX
Bronco OBX
Got a rock chip, and it seems to have spread quickly. Is it repairable or do I need to replace the windshield? If replacement is needed, should I push for OEM windshield or is aftermarket fine?
Ford Bronco Windshield rock chip/crack. Repair or replace? IMG_2731
Rick66
Rick
MN
F150(sold), S197 GT C/S (sold) 22 2DR BB EG SAS V6
Looks like the one I picked up. Replacement was necessary. I was able to get an OEM. Contrary to what many have experienced here, my insurer chose Safelight, and the installer was great.
Ford Bronco Windshield rock chip/crack. Repair or replace? 20230728_134900
Sunday Money
In hindsight, esteemed Bronco6g forum guru @sbasham82 would have recommended "DO NOT buy a Bronco unless you own a glass company", otherwise you'll experience "broken dreams" https://www.bronco6g.com/forum/threads/broken-dreams.115210/
Joking aside, I think the length of the multiple cracks would call for replacement (and if that 6 o'clock crack is touching the edge that itself would keep it from being professionally repaired).
I echo @Rick66 and had a great experience with Safelite too through my insurance.
RedTailHawk
2024 Ford Bronco Raptor
I have a crack in the same exact spot. Seems more like a structural caused crack rather than a rock chip. I'd be curious how many others have experienced this crack.
jrollo7
James
NY
Range Rover Sport
Replace
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
I have one in the same area as well. A little more towards the bottom corner.
I think it is just coincidence, these don't appear to be structural as it would seem there is a clear impact.
CORRIGAN
Everglades
Corrigan
Anaconda MT
2024 Bronco
Everglades
Mine was higher and about the same length. Just curious, i had a hood deflector originally installed, do you have one on your ride?
Ford Bronco Windshield rock chip/crack. Repair or replace? 20240907_165630
RedTailHawk
I didn't have the deflector when it happened, but I've since added one
KJSnider
KJ
MN
2023 Bronco Badlands 2D 2.7
That windshield is a goner.. I'm always asked if it can be covered up with a dollar bill.
Immediately after my replacement, I put an Exoshield Ultra "screen protector" on mine. So far so good. Watched the videos, took my time. I'm really pleased with the outcome. If it semi protects it for a couple of years, I'll be happy.
CORRIGAN
Everglades
Corrigan
Anaconda MT
2024 Bronco
Everglades
It looks to me like it sends debris higher, but not over the entire windshield.
Since this happened, I have stopped tailgating. The horse is a rock magnet!
Summit981
Paul
Maryland
Porsche Cayman, MINI GP2, MINI Countryman
I had a vertical crack in the exact same spot caused by a loud “smack” of a flying pebble/stone on I-70 in Maryland. It didn’t run to the bottom edge nor continue to run up the windshield. It just remained the same length. I kept an eye on it to see if it would get worse and it never did. That was two and half years ago. 😌
themendoza001
TX
Bronco OBX
Yes I have the Aeroskin 2 on mine
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
My stone chip and crack are on the right side and a bit smaller. Mine would probably be considered unrepairable by a professional, but I used a do it yourself kit on it, and so far so good. You can still see it, of course, but it hasn't spread since.
If / when it spreads I will replace the windshield. The aftermarket glass is most likely made by Fuyao - the same company that makes the glass for Ford. It won't have the Bronco logo, but otherwise should be basically identical.
