Windshield Cowl Gap
Icetek
Oeiras Portugal
2012 BMW F21, 2024 Harley Road Glide, 2009 Harley Street Glide
I never noticed this before, but today I was doing a deep clean of the windshield and hood when I noticed it.
I don’t have any other Broncos over here in Portugal to compare it with.
Is this huge gap in the middle normal?
It’s tight on both sides, but there’s maybe a 3/4" gap in the middle.
Ford Bronco Windshield Cowl Gap 1786299962719-6y
Thanks,
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
It's a known issue. Some have had luck getting it replaced under warranty. I was not so lucky with my local dealer. I may eventually try with another dealer, but I haven't yet. There are a few threads about it here.
CalvinT
Calvin
Phoenix, AZ
It's tricky getting the cowl in properly. Do it wrong and you'll have a gap. You need to pop all the tabs where the cowl snaps in behind the firewall. Then you can snap the cowl under the windshield. Then snap the tabs in behind the firewall.
totaljustice
Kevin
Middle Sackvegas, NS
I had the gap as well but my dealer replaced the cowl for me under warranty. No gap appeared since at almost 2 years into ownership.
Lambhair McDaniel
Marietta, GA
1997 Wrangler, 2024 Bronco
I have the same. Is this just a superficial issue or could it cause problems? I have wrestled with raising it for warranty work because I am not sure it is important.
CalvinT
Calvin
Phoenix, AZ
I would.
The gap will accumulate junk over time, you don't know what problems that willl cause.
Icetek
Oeiras Portugal
Thanks for the pdf... strange design with the colors to the right with no text on them but the procedure looks clear enough.
Icetek
Oeiras Portugal
Thanks for the replies. Good to know it is not normal.
I've only been to 1 of 2 local dealers here - the only one that would look at the truck. They did the initial service but only fluids and filters not any software or anything. So not sure what their approach to this under warranty might be.
I might wait for a cooler day and try it myself.
Like CalvinT said it will be a collection point for trash and debris over time. So would prefer to get it fixed.
shaw
shaun
California, Santa Clara
2024 Bronco
Thanks,
That’s more gap than I’d consider normal. These old Broncos can have some variation, but if it’s tight at both ends and opens up to around 3/4" in the center, I’d suspect the hood or cowl alignment before assuming it’s supposed to be that way. I’d check that the hood is sitting square and that the hinges/mounts aren’t pulling it up in the middle. Also check the windshield frame and body mounts since a little body movement can change that gap quite a bit.
I’d get some measurements from side to side first before adjusting anything. No need to start chasing it until you know which part is actually out of alignment.
CalvinT
Calvin
Phoenix, AZ
The hinges won't affect it. But if someone has pulled the cowl up, they won't be able to get it back in place unless they follow the right procedure.
totaljustice
Kevin
It isn't going to harm anything other than the possibility of crap getting down inside there more easily. If you start getting things like leaves, pine needles, road salt, etc down in there it will retain moisture and begin the car cancer where you can't see it.
Icetek
Oeiras Portugal
Yep. Which is why I asked. I know hoods are not water/debris proof but this looked wrong. Would like to keep all the extra stuff out for the reasons you mentioned.
