Window Seal Isn't Flush and Window Doesn't Roll Down
chaseman210
Hey, everyone. I haven't had any problems until today. I noticed my driver's side seal where the soft top meets the roll bar is open. I can stick my finger through to the inside of the car because the seal isn't lining up. On top of that, my window doesn't roll down when opening the door, so I have to manually roll down the window to get out because the glass is caught. Has anybody experienced this or know how to fix it? Thank you for any help!
Ford Bronco Window Seal Isn't Flush and Window Doesn't Roll Down 20220721_162728
Ford Bronco Window Seal Isn't Flush and Window Doesn't Roll Down 20220721_162749
Ford Bronco Window Seal Isn't Flush and Window Doesn't Roll Down 20220721_162736
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I doubt a window reset will correct this - Best bet is to take it into your dealership and have them fix it. Thankfully, we have warranties.
rtazz17
Connecticut
2022 Ford bronco big bend
Did you try the window relearn for the heck of it?
WatchYourSix
NY
2020 Explorer ST, 2021 Bronco, 2022 Maverick
This happened to me a few weeks ago for a few days, then it just stopped and worked as normal again. Try the window reset though, if you haven't already.
chaseman210
Thank you for the replies! The window reset worked. I guess I still need to get the seal checked out. Maybe it's like that normally and I just haven't noticed?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello there. Can you please send over a private message with your VIN and the name/location of your local Ford dealer? I would like to look into your window seal concerns on my end.
JohnnyBronco
Pennsylania
X4
Mine acted up today and the window reset worked like a charm. No seal damage. Had top half open and windows down for ride home from work. Sugestion to watch. Do not close window all the way when door is open, only when closed
