Window issue
bmuelz3
Brandon
Buffalo
Ford fusion
The other day I was driving on the highway. It was super windy that day and I was also going about 75-80. While i was driving my window popped out it's groove at the top at the roll bar. It was open on a slight degree to the left (this was my drive side window). There was a bunch of wind coming in and I rolled down the window to help prevent unnecessary stress on the window. I pulled over and rolled up it was okay after. It only popped a little bit twice after. Any one else have this issue?
I drive a 2 door btw.
MyBroncoNotYours
Good Try FBI
SoCal
Ford Focus
I recall another thread with this exact situation, going 80 down the highway.
Martinez_0n
Nico
71 Camaro, 03 2500hd
Yup, this just happened to me today while driving at around 80mph. Windy up here in North Texas around 23-30mph winds. All of a sudden my driver-side window popped out of place and was super loud. Had to pull over and lower and raise the window a few times before it sealed again. Not sure why this only happened to the driver's side and both. Maybe the direction of the wind. Sucks especially when you are on the phone. Good Luck if trying to use Bluetooth. I also drive a 2dr hardtop
r3mwilso
Renee
Houston
Elantra
r3mwilso
Renee
Houston
Elantra
Hi there! I just bought a two door and had the exact same issue while driving on the highway on a windy day. The driver side window popped out repeatedly. I’m taking it into the dealer tomorrow. Were they able to fix yours?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Can you send us a DM with more information? I’ll see how I can assist on my end. Thanks!
Outbound Exploration
2018 Chevy Sonic Hatchback RS, Looking to upgrade to Bronco*
Driver side window as well. This weekend coming out of Joshua Tree, CA. We pulled over lowered window down, open and closed the door and it finally stayed sealed.
Will monitor next couple of days but not a pleasant experience.
Fender Bender
Bob
Maserati, Jaguar, Dodge, Wildtrak
Exact thing happened to me yesterday on a very windy day going about 75. Took about 5 times of rolling the driver's side window down and up before it finally seated properly. My wife was on the phone and it was so loud she could barely hear the other person.
ctandc
VA
'22/23 Bronco, 96 EB Bronco
FORD SSM
SSM 50477 - 2021-2022 Bronco - Short Drop Window Feature - Contact With Weather Strip When Opening
Some 2021-2022 Bronco vehicles may exhibit a side door window that gets hung upon the upper door weatherstrip when opening the door causing resistance to opening. This may be due to an incorrect alignment of the side door and/or window. To correct this condition, ensure no damage exists to the door, latch or related components and make necessary repairs before continuing. If concern persists, perform the Up/Down, Fore/Aft Adjustment (steps 1-15), refer to Workshop Manual (WSM), Section 501-11, Front/Rear Door Window Glass Adjustment Procedure. If the concern has not been resolved, perform Pinpoint Test K located in Section 501-11 of the WSM.
APPLICABLE VEHICLES
2021 - 2022 TRUCK: G1 U725N BRONCO
I've attached the adjustment procedure if you don't want to take it to the dealer
NOTE it's just steps 1-15
breeox
Palm Springs, CA
2022 Ford Bronco Outer Banks 2 Door
Same issue with my 2 door hardtop. Was driving over the grapevine in Southern California in rain and wind and I was pretty sure the window was going to break off. I was so concerned I rolled the window down halfway and drove in the rain with open window for an hour as it kept popping outwards due to high winds and the stress on the window seemed too much for it to handle. Has Ford made mention of any risks or fixes on the horizon?
Ford Motor Company
Dearborn
Hi there. This window concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
breeox
Palm Springs, CA
Will do, and THANK YOU @Ford!!!
Gargantua
Chicago
M1083A1
I had this happen as well on two separate trips. Exactly as described by others. Once in the winter and again heading west on the highway. On the last trip it happened 3 times but not on the way back. Driving into a headwind at a high speed seems to be the issue.
I also wonder if the fresh air / recirc switch matters if there is a positive pressure forming in the cab assisting the window to pop out?
Did anyone get any work done in this to address it? I did the window reset after the first occurrence.
This is what it looks like
https://share.icloud.com/photos/0ccZ4mUsqEsfGzi87f1_MxYEA
Ford Motor Company
Dearborn
