Wind noise passenger side hard top
Carbon Gray
Rick
Long Island
2025 Bronco
I was curious if anyone else with a 2025 two door Bronco is experiencing a wind noise that emanates from the passenger side hard top behind the passenger seat? One other question, is there a way of recalibrating the speedometer after installing 265/75R16 tires?
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
It's not just you. Common complaint, though not as prevalent on everyone's Bronco - or rather some owners are more tolerant of the wind noise than others. Take your time and read up on the many crowd-source solutions where weatherstripping is used in an attempt at mitigating the noise.
Gbauer
George
Hanover, PA
2024 Badlands 4dr, 2020 Mustang GT/CS premium, 1968 Mustang Coupe
Doc TOC
Los Angeles
Expedition Max, Fusion Hybrid, BMW 5 Series, HD Road King
Several good blogs on the forum for both of your issues
In Google, type this:
site:bronco6g.com hardtop wind noise 2-door
site:bronco6g.com forscan speedometer recalibrate
You will feel very informed afterwards.
Go get 'er done.
dougcjohn
Doug
Iowa
‘24 F450 Limited, ‘25 Bronco Raptor, ‘16 Smart Fortwo, ZX12R
Adjust the brackets. Eventually youll hit the sweet spot. Also get a 1/2" foam pipe insulation.
https://www.lowes.com/pd/K-Flex-PE-SEMI-SLIT-1-2-in-WALL-X-5-8-in-I/5013107371
Take the two front panels off, stuff it down in the gap between the metal and door edge.
There's numerous threads on noise reduction. We're all chasing it.
You touched on my question, adjust the bracket.
2 or 4 door… sounds like ft right clamp near windshield is a leakage point.
I’ve read through many, but skimming or speeding through I may have missed.
Was there a thread discussing adjusting the clamps?
jtpasto
Jerome
Salmon Idaho
2022 Bronco
2022 2 DR Black Diamond. Make sure your window is raising up after the door is closed. The passenger side on our Bronco periodically stops and the window raise function has to be reset.
helifino16
Ron
Mount Sinai, NY (Long Island)
I definitely have this issue. I just lean into it and crack open the Passenger Window. That way, I know what it is. lol
Gbauer
George
Hanover, PA
I don't recall but its not hard to figure out. Just loosen the bolts and start moving the brackets a little bit.
