Winch accessory question - cover/line shackle?
jclark
Jeanette
Mid-Michigan
I'm planning for a winch install on my rig -
  • RC high mount plate
  • LoD frame horn plates
  • Warn 10-S (probably Platinum for the wireless remote and other features)
  • Warn control relocation (to put the control box in the engine compartment) (probably the option from BAMF)
This configuration checks a number of boxes for me (no impact to approach angle, re-use of 20" bumper mounted light bar, not blocking my grille letters, etc.)
So here are my lingering questions...
Any cover options that are low profile to protect the winch line from sun exposure?
Which winch line shackle are most people going with?
Any other accessories I need to plan for?
SierraBronco
We carry both hard and soft shackles. Both are great and when used appropriately EG-don’t use a soft shackle in a D-Ring mount then be surprised when it breaks. You never know what other rigs do or don’t have when you either need their help or they need yours, so easiest to just carry both. We have two hard and four soft.
Also consider snatch blocks. We have two of the conventional snatch blocks rather than the new static options that are becoming more popular with the use of synthetic rope over cable. The simple reason is heat and drag. If using the static blocks in high temps, you’ll get a lot more drag and wear the rope faster. There will be evidence of this as you’ll potentially leave the coating of the rope on the donut thingie. Probably not a concern if you’re up north but with summer trips to Moab it’s something I’d rather not worry about. And with snatch blocks comes a way to attach them, so you’ll want a long strap or two in the event of redirects. Plenty of companies make recovery kits of various pieces from basic to extreme. If you want all American made go with Yankum. If you want to keep Chinese kids employed there are plenty of options for that as well. We also carry a kinetic rope. Not as much for kinetic (potential?) energy pulling but for using as a tow rope. That little bit of stretch makes towing much more pleasant than a strap.
jclark
jclark
Jeanette
Mid-Michigan
Thanks! I carry recovery for kinetic recovery to include 20' and 30' kinetic options, soft shackles, tree strap, and hard shackles But winch recovery is going to need to add to that. First decision is what to put on the end of the winch line....
contented
Karl
Central Fl
BMW M2 Competition
Here’s my setup. Warn VR Evo 12S on RC Mount. Like most others, I carry soft shackles, tree saver, 30’ kinetic rope, 10‘ kinetic rope bridle, hard shackles on all four bumper corners, and 20’ strap.
Ford Bronco Winch accessory question - cover/line shackle? IMG_1729
jclark
jclark
Jeanette
Mid-Michigan
Nice setup. What winch line shackle did you use?
Chrome_Pony
Chrome
The Great Land
That is a Factor 55 Flatlink - E in grey.
I have the same, but the Superwinch 1571 neoprene cover is more my speed. Stretchy and one drawstring instead of about 5, 2 zippers and no stretch on the Warn winch cover.
contented
Karl
Central Fl
BMW M2 Competition
I had to smile, but you sir are indeed correct. :)
Chrome_Pony
Chrome
The Great Land
It was a hard-learned lesson.
My winch is more recessed than yours and has an Anderson 350A QD, which combine to make it exponentially worse to try to finesse that tightass Warn corset around the winch.
Ford Bronco Winch accessory question - cover/line shackle? 20240119_222526
Felix808
SRV CA
Personally I don't think the Warn 10-S needs a cover as it is a sealed winch. I protect the rope from the sun & junk with some high density foam & a strip of Gorilla Tape. I just remove it whenever I need the winch. Works for me, YMMV 🤠
Ford Bronco Winch accessory question - cover/line shackle? IMG_6939
SierraBronco
We just did a brummel splice front and rear. Winch line tucks in and is protected from hitting rocks by the fairlead up front
Ford Bronco Winch accessory question - cover/line shackle? IMG_1685
Ford Bronco Winch accessory question - cover/line shackle? IMG_1589
