Will installing upper strut bar adversely affect offroading capabilities?
buzpro
Binky
Tacoma
would installing an upper strut bar adversely affect offroading capabilities?
Straight 6
Brad
Ca
BMW
Why would you install a strut brace?
NateL
Nathan
RI
2010 Ford F250 2014 Ford Escape 1947 Ford PU
Incognito
Phoenix
2017 jk
OP, if you're looking to increase street performance, switch to 18" rims for 32-33" tires, 20" rims for 35" tires.
Add tires oriented more for on road than off, like the Pirelli AT plus, and you'll be GTG.
KJR50
K
SoCal
I'm not telling U.
OP needs some bling to put his/her hand on while leaning over the engine bay.
Now if you'll excuse me I need to get back to my French braided brioche and California condor eggs breakfast.
Straight 6
Brad
Ca
BMW
Do you guys think a bigger rear sway bar will be available? I don't want the bronco to push like a pig if I corner hard!
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
There’s currently no rear sway bar. So anything added is bigger
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
so instead of being a d!ck, thought i'd answer OP. putting a strut tower bar on a body on frame car/truck would not affect anything as the body does not really affect the rigidity of the frame unlike a unibody car. for stiffening up the front end you'd look at sway bars and shocks to help stiffen things up. with such a large sidewall in the case of the bronco (like said above), getting a lower profile tire. would drastically affect handling.
buzpro
buzpro
Binky
Tacoma
Finally got an understandable answer .... THANK YOU @King Luis
