NJNMDoc
Southwest
Bronco Wildtrak
This is getting confusing, I installed the "Rough Country 2.5 inch lift kit sku:51071 ", only,
Spacers on top of coilover assembly, upper control arms, diff. drop, track bar drop. No collars.
I looked for the email from Rough Country saying it would fit, but must have deleted it. The install went exactly as the instructions showed, nothing, other than the skidplate, had to be modified.
The steel skidplate was the only modifying that had to be done, I don't believe it had anything to do with being a HOSS 3.0. The diff. drop lowers the diff., the skidplate isn't lowered so it makes contact.
Hey Dan- are you the guy that 86’d the lower strut spacer from the RC level kit? I was pretty sure it was you?
JackTripper
The Beach
Enough
I just called rough country. They said that the standard 1 inch lift kit will NOT work with the HOSS. They are working on getting a HOSS equipped Bronco in Shop to make one that fits. I will wait for RC or FOUTZ to make the correct part.
These are expensive toys, I do not want to run the risk of ruining anything.
0ne
Nate
CO
Flex
Then leave it stock and get off this forum’s modifications pissing contest while aftermarket companies are rushing product to market or not quite there yet 😉
Wildtrak is a great stock spec! Enjoy! 🤠
JackTripper
The Beach
Enough
I have no problem modifying, I just wanna make sure I make the correct modifications that won’t affect the reliability of the vehicle. Your statement is moot. Thank you for your comments.
0ne
Nate
CO
Flex
You’re funny, good luck! 👍
Geronimo
Wisconsin
Tacoma, Bronco Badlands Sad on order!
I had a local shop order the ki to put on my 23 Wildtrak 4 door. I don't see a diff drop spacer in the kit. Also, any chance you could post a picture of where you cut the diff skid plate? And wondering if alignment was easy? Thanks
TexasDan
TexasDan
Dan
Corpus Christi, Texas, USA
2022 Bronco
The L shaped bracket(with 2 tabs) and cylindrical spacers, both top center in pic.
Ford Bronco Wildtrak HOSS 3.0 Build almost done, hahahahahaha! IMG_0237 (1).JPG
Hopefully you can see where I lengthend the existing opening. I added the flat strap for protection(not required). Also a slight grinding on passenger side, both are obvious when holding skid up to vehicle to reinstall.
cynicalrider
NJ
First gen taco
So you installed a spacer lift on top of high performance shocks? Did you happen to extend your bump stop to accommodate this? The upper control arms I am sure help keep the UCA's off the spindle but curious to see if you are maxing the CV's at full droop too.
Tishomingo
CA
2022 Bronco
I think lots of people agreeing how silly that looks!
Good reminder that less is more sometimes. The orange paint and graphics are not helping anything here. Maybe a less capable Wildtrak now with these changes.
TexasDan
TexasDan
Dan
2022 Bronco
Thanks for your input, I suggest you don't do your Bronco that way.
My Bronco my way!
Geronimo
Wisconsin
Life would be boring if everyone had the same of everything. Think about it, same house, dog wife kids clothes, haircut, car. Luckily we are all individuals with our own likes and tastes and "personalities". Hopefully you don't take this in a bad way, but maybe you could work on the last one just a little bit. I learned early on that if you don't have something nice to say, don't say anything at all. 🫤
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I had a shop install the rough country kit and it worked perfectly to raise my front end an inch. HOSS 3.0.
Ford Bronco Wildtrak HOSS 3.0 Build almost done, hahahahahaha! IMG_3623
Raised the front end 1 inch? So sounds like you did a 1” level kit and not the 2.5” RC lift kit that’s been the primary discussion in this thread.
