wild track vs badlands SAS
Ranbronc
Pa
Early Bronco
had a 21 badlands SAS
need a new bronco
I ordered the first on and it was perfect .
finding wildtracks out there they look similar to the badlands I had.
what happened to the high package all i see now is lux and mid
21 is not buffing out
BroncoChallenger
2024 Bronco
I'm no expert but I think the high package is now called the Lux package.
timbits588
WNY
2017 Expedition EL Limited, 2023 F-150 Lariat, 2023 Bronco Wildtrak
Holy cow, hope you're okay!
I just bought a '23 Wildtrak and as I was doing all the looking and researching, I noticed the '23s list high and lux packages separately, but the '24s combine the two packages into one: high/lux (at least that's how I saw it listed on window stickers numerous times).
Not sure if that helps, at all, but that was my experience looking at a few hundred over the past few months.
ABQ_Bronco1982
Jon
Albuquerque
2024 Ford Bronco Wildtrak
Just picked up a 24 wildtrak. The high/lux are the same package now.
Shadowsquatch
GA
Cactus Grey 2-Door Wildtrak
First, I hope you're ok. That's a heck of an impact! I'm also looking at these 2 trims and yes, the High/Lux package is the same now.
Biggest differences in a MY24 would be the Badlands would come with skid plates from the factory, and you could option it with a 7MT.
WhiskeyCity
Shannon
Bardstown, KY
2023 Bronco Badlands Sasquatch 2.3L, 7spd
That's some "Final Destination" looking carnage right there. Thank goodness you're ok. WTs won't have the sway bar disconnect, that's about it. Hoss 3.0 is nice on the newer ones.
Ranbronc
Pa
Early Bronco
Looking at my picture I was walking better at the accident than I am now, ( I'm gray shirt kneeling)still in the ICU working on getting transferred to a rehab facility to get walking again, broken hip and leg more like cracked so no surgery they want me walking as it is .
Ranbronc
Pa
Early Bronco
So hoss 3.0 is the suspension? Don't see it listed on the window stickers.
My use is light off roading cause it my only vehicle, I tow behind my RV.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Were you side-swiped by an oncoming semi?? Glad you survived that.
I have a 23 2dr BL and I would recommend a 23 WT. It has what you need, if you want to, you can add what's missing easier than the BL. Mainly, the BL gets the e-sway bar disconnect (you can add and wire to an aux switch fairly easily), plates and the Trail Armor (non-step) rock rails. Maybe I'd say a non-Sas BL if you got a good deal.
The 23/24 WT gets Sas automatically, you get non-rock rail steps (usually) plus HOSS 3.0 and the upgraded steering rack. Note the 23 BL does not get the HD steering rack or the HOSS suspension. Also, the 2.7L.
If you can find a 23 that's what you want, get the High package. Otherwise, I'd probably say the High/Lux (really, it's just Lux). Although in 24, the mid package gets the big screen and you have fewer nanny's, so it's not that big a deal really.
Ranbronc
Pa
Early Bronco
2 way traffic dump truck tried to pass the trucks in front of him ,came into my lane,guard rail there no place to go, happen fast within an oh shit .
Ranbronc
Pa
Early Bronco
I like the leather seats in all the Ford's I have had they are always comfortable.
Heated seats cause I'm old.
12" screen cause old .
I want lockers 315 tires and a good suspension.
I will probably be out in Utah next year and want to hit the off-road stuff, not red black trails just scenic stuff .
Done want to work on stuff needs to come with it, I will add a RockHard 4x4 bumper for towing easy bolt on.
  • Like
Reactions: Los
Ranbronc
Pa
Early Bronco
I have had no issues, I use NSA towing stuff it's all mechanical and I take out of tow when I stop for the day
