Wife's '23 WT hardtop doesn't look right
Techun
Pa
BD, 2.7, MIC, 4dr
Make sure you put it on and take it off in the correct order. Simply looks like it hasn’t been installed correctly.
I don't think it would be possible to install the front panels in the wrong order
Razorback
Razorback
Dallas
Lincoln MKX
So it appears to be a couple of issues. Thanks to @Ksjrb03 for the TSB on the drivers side. Seems like I can have the dealership do it in a snap given no parts need to be ordered. The passenger side feels like some adhesive is missing on the rear and front of the weather stripping. I'm sure they can to that at the same time.
Here is the front passenger weather stripping.
Ford Bronco Wife's '23 WT hardtop doesn't look right IMG_20230225_114842
Here is the rear passenger weather stripping
Ford Bronco Wife's '23 WT hardtop doesn't look right IMG_20230225_114533
Both cases seem like they stopped short on the adhesive. Could have the dealership handle it, but afraid they would goop adhesive out the sides, so I might just handle the weather stipping myself and let them handle adjusting the driver side....
Ksjrb03
Tx
F250
That’s how the weather stripping is supposed to be, nothing wrong other than a shitty design lol. Your mid panel will have the same loose edges.
telenerd
Laramie
Subaru
Mine looks even. My guess is your weather stripping isn’t quite even and too much material.
Ford Bronco Wife's '23 WT hardtop doesn't look right CB356B8E-A270-4B25-BE11-D06E19A32CA9
Ford Bronco Wife's '23 WT hardtop doesn't look right B40D9541-CFD6-4D82-9D7B-1953396F6938
RDNK
Doug
Oregon
2017 F150
Mine looks good.
Ford Bronco Wife's '23 WT hardtop doesn't look right 8C50AFF8-E5AC-466C-B576-F167AB67ACA8
Vince
Rochester, NY
Terrain, Acadia
There was a message sent to the ford dealers about this and there is a fix. Some (mine included) had this poorly lined-up panel problem. I had a leak in mine too. The dealership had me come in, made some adjustments, and it's fine now. Still loud as hell...
area50one
AZ
Bronco 4dr 2.7 BB
I have the exact same looking drivers side panel (sticking up in the middle). Also the entire passenger side doesnt line up right. Looks like I will have to let the dealer adjust.
flowingaway
Tennessee
2016 Toyota Tacoma 2023 Bronco Badlands
You mentioned coming to TN.
When you come, meet me and I'll give you my soft top for it. 😉 It's a beautiful 2023 with less wrinkly wavy windows. I think you would love it.
Deleted User 5719102
Who's
On a Lake
22 2dr
The center latch points are adjustable. You can take the t-panels off, pull header trim piece and loosen/adjust and reinstall. It is something you can do in your driveway. Unless you are allergic to a small amount of manual labor and have no common sense about ya, why take it in to the dealer and waste valuable breathing and mind decay? I would rather sit in my yard watching flies lust over fresh dog poop than sit for hours waiting hours on other idiots to figure simple shit out.
Razorback
Razorback
Dallas
Lincoln MKX
Doubtful we'll sit there. Our 21 Bronco can get us around for the day. Everything I do myself on the Broncos. This I would just as soon have the dealer do for free since it's a Ford mistake. It's by the theater so I'll just go on an afternoon date with the wife. They confirmed they can have it done in an hour and a half. Bronco service manager said they had to do the same on his Bronco and others.
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
Thanks to all that posted. I just had to go look at my 2 DR and took this close up of my DS panel. I then took it off and reinstalled it. no change. I'm hopeful that it'll settle in with time. The truck has yet to see temps above 35 since I brought it home 4 days ago. Aside from the height difference both panels seem well aligned. Is there a big cause for concern here?
Ford Bronco Wife's '23 WT hardtop doesn't look right IMG_8747
FleshTuxedo
A
PA
'22 OBX 2dr.
That's how my 2dr. looks. Seems normal
Techun
Pa
BD, 2.7, MIC, 4dr
Took mine into the dealership for a few issues, including this.
Before:
Ford Bronco Wife's '23 WT hardtop doesn't look right IMG_20230225_093419755
And after:
Ford Bronco Wife's '23 WT hardtop doesn't look right IMG_20230306_180955906
Ford Bronco Wife's '23 WT hardtop doesn't look right IMG_20230306_180836173
It's hard to tell if it's improved or not. On the short drive home maybe it was a little better. If there's still wind I may try and lower the inner/front driver side one?
Who's
On a Lake
22 2dr
My hardtop front panels sit a little higher in relation to the rear shell. And every other one I've seen is the same. I believe that is purposed design element for water flow and airflow during driving. It allows water to pass uninterrupted instead of being blocked by seal and shell or standing water on seal.
Razorback
Razorback
Dallas
Lincoln MKX
I ended up raising the passenger and lowering the driver to match.
Ford Bronco Wife's '23 WT hardtop doesn't look right PhotoGrid_1678140538300
