Wider Stance
King_Bronco0327
Orlando
So I have a 21’ Base Sasquatch and my goal is to widen my stance without adding a spacer, adapter, offset rims (because I like the stock Sasquatch rims), or a whole coil over lift kit. I don’t know much about suspension system but any advice on a particular product or method I could use that wouldn’t compromise off-road performance?
edit: I found this by wicked creations: https://wicked-creations.com/wc-2021-ford-bronco-3.5-lt-kit/ Not sure if this would make sense or if theres an alternative.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
74weld portal axles will poke you out~ 3" per side (and lift you nearly 4")
Lak34ers
Troy
Seattle
I went with RTR zero offset. Widens about 1.5 inches. Also went with 6100s to level and lift about 2 inches....just looks better in my opinion and definitely drives better than OEM SAS
FleshTuxedo
A
PA
'22 OBX 2dr.
But will basically cost you the same as a base bronco :ROFLMAO: :)
Copperhorse73
Justin
Mooresville, NC
Just swap out your Sasquatch fender flares for narrower ones or a flare delete. That’ll make it look wider anyways. That or drop 20-25k on portals
Silver-Bolt
Eureka, MT
Sniper
Luis
Maryland
2023 Bronco
Been trying to find narrow ones I like. No luck.
Baja Blue Bronco
Arlington, TX
2022 BRONCO, 2016 f150, 2004 Tacoma
I have a set of flares from my 2022 badlands, swapped them out for the sas flares. only 80 miles? on them.
King_Bronco0327
King_Bronco0327
Orlando
Portals are great, but so expensive I might as well go with a traditional lift kit.
King_Bronco0327
King_Bronco0327
Orlando
I saw them run bead lock ones before but couldn't find them on their website. Was that just a prototype?
King_Bronco0327
King_Bronco0327
Orlando
Agreed. But my end goal is to get the APG wide body kit. And I want fill that gap between the SAS stance and those fenders.
King_Bronco0327
King_Bronco0327
Orlando
Lak34ers
Troy
Seattle
Not sure. I went with EVOs. Crazy how light they are around 26lbs and SAS are 36. Also like Satin Black vs OEM Gloss Black...stays clean longer and doesn't show scratches in sun like gloss. Been really happy with the so far. Sold OEM and almost paid for RTR with 0 offset so easy choice for me.
