Status
Not open for further replies.
69BroncoX302
1969 U15, 2021 First Edition
Bring love to the 2dr as well.
JB1901
KS
'21 Badlands Sasquatch Lux
A few questions:
1: What is the weight of the bumper?
2: What standard color is the BAMF logo on the front? The website shows orange but another photo above shows black.
3: Are the bumpers pre-drilled for fog lights in a particular pattern/spacing to fit a specific light?
4: These wouldn't have a problem installing on a 2.7L Sasquatch Badlands?
1Five1 Garage
florida
Bronco Big Bend, F350, 4Runner, 52 Ford F1 RatRod
1. Rear plate bumper with Dual swing arms and tire carrier
2. Frame mounted bolt on Rock sliders 4d & 2d
3. Full Under belly skid plates, shock skids, LCA skids, Rear diff skid
4. Soft-top Roof rack (with the factory soft top still foldable)
5. Rear gate reinforcement for larger tires/tire delete (modular system)
My Black Diamond will need all of this.. ) as soon as I get it that is....
BAMF
BAMF
Jerry
Benicia CA
www.bayareametalfab.com
Two 2021 Broncos
@BAMF
Here's where my hitch hits plastic
That's not the only problem I encountered though.
With the 2 middle bolts in and not tightened there is no way to get the outers in. Holes are way off.
At least they are equally off 🤷‍♂️😄
That is installed backwards . Turn it around the other way the holes are offset on the frame. They should line right up once turned around to the correct orientation.
Dirtyjed
Orangevale
05 Dmax, 86 FunRunnah, Tiyoda truggy, Honda shi
So this is the side thar faces outward?
Ford Bronco Who Is BAMF? 20220122_200046
And this faces towards exhaust?
Ford Bronco Who Is BAMF? 20220122_200103
Edit: If I try to install it the opposite way I did before the holes for actual receiver don't line up with a standard ball hitch.
Ih
Ford Bronco Who Is BAMF? 20220122_202451
How I originally had it on truck works though.
Ford Bronco Who Is BAMF? 20220122_202632
kodiakisland
Arkansas
Ih
There is an installed picture on this thread: Bamf hitch install issues? | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
I've got one still in the box that I'll install next week. Sounds like it might be fun.
Dirtyjed
Orangevale
kodiakisland
Arkansas
If you install it that way it's basically pointless as none of the 3 hitches I tried will line up with the pre-drilled holes on the receiver.
But they all work on both my Duramax and 4runner.
I haven't even opened my box yet. I plan on using it for a cargo carrier short term but will hopefully be getting a high clearance bumper with it integrated into the bumper. I'll install next week sometime. Hope I have better luck with mine.
Dirtyjed
Orangevale
@kodiakisland I hope it works out for you as well.
Bike rack and recovery point were 2 main reasons I got it.
BAMF
BAMF
Jerry
Benicia CA
Two 2021 Broncos
Ih
Now that's not right! The hitch pin holes should be other way. I can see why you would try to install it the other way after installing putting a hitch in the receiver.
We have been using that receiver plate for a few years in our rear bumpers and that is the opposite orientation then our bumpers. Not allowing the pin to reach unless its a 8.5" HD hitch or longer "I just confirmed" on one of our bumpers. That's a design flaw on my end the lower plate should be flipped bringing the hole closer to the back.
We want them to be usable even with the light weight short shank class 2 hitches and bike racks so I'll be replacing all the hitches that were shipped out next week.
Thankfully only a few dozen have been shipped and you are the only person that's actually tried a standard length shank in the receiver so far. We have hundreds ready to assemble so getting replacements out with the pin hole in the correct location next week will be simple.
The hitch you have now will work with extended 8.5" or larger hitches. it's yours to do what you please as you will be receiving a complete replacement.
Find a buddy to sell/give it to that's willing to drill a new hole or buy an extended hitch and they can use it. It's still a perfectly usable hitch they just need a longer shank to reach the pin hole.
BAMF
BAMF
Jerry
Benicia CA
Two 2021 Broncos
A few questions:
1: What is the weight of the bumper? All in about 95lbs
2: What standard color is the BAMF logo on the front? Standard is black
3: Are the bumpers pre-drilled for fog lights in a particular pattern/spacing to fit a specific light? Our fog light mounts are slots. you can pretty much mount any fog in that location that has a 3/8th or smaller mounting stud. And slide them from side to side to locate them where you want.
4: These wouldn't have a problem installing on a 2.7L Sasquatch Badlands? Not at all, we haven't seen any trim issues with the bumpers.
Status
