Where's the underhood light???
Tcarp1
Travis
Newcastle, CA
2021 2 Door Badlands
Well there isn't one! So I decided to fix that. I am going to eventually make a bracket and mount an arb compressor under the hood. Without some lighting under there it would be a pain airing up at night. I used one of the KC cyclone pod lights. I bought the two light set but ended up only using one of them. There wasn't alot of places to mount them under the hood with the sound deading piece. Fortunately there was one recess that was large enough to fit one. I drilled out the hole and nutserted it and used a stainless 1/4. 20 to attach it. Ran some wires and a switch and tadah!
Ford Bronco Where's the underhood light??? 20220313_170258
Ford Bronco Where's the underhood light??? 20220313_170305
Ford Bronco Where's the underhood light??? 20220313_170311
Ford Bronco Where's the underhood light??? 20220313_175735
Ford Bronco Where's the underhood light??? 20220313_175138
Tarheel_Wes
Wesley
FJ
Very nice. I just added 4 LED pods in my cabin. It came with 6, so I was gonna put the other two under my hood.
Never used “nutsert”
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Well there isn't one! So I decided to fix that. I am going to eventually make a bracket and mount an arb compressor under the hood. Without some lighting under there it would be a pain airing up at night. ...
Ford Bronco Where's the underhood light??? oh-boy-here-we-go-1-
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
@4x4TruckLEDs.com has an ARB mount. If you search the forum, there may be other options too…
604Bronco
British Columbia
www.bronco6g.com
Apple Blossom
Nancy
Ontario, Canada
2018 Ford Edge
Y 1971 Datsun 240 Z had a light under the hood. It had a holder and a cord and you could detach it and look around.
newclubfront
Home
Car
Could you please take a picture of the christmas tree push-pin that your removed next to a ruler? I recently ordered the hood liner from my ford dealership but the push pins were outrageous. They wanted 13 pins * $6 = $78. I declined because I thought I could buy aftermarket christmas trees. Is there anything special about those push pins?
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
cclkramer
Coeur D Alene Idaho
2000 ford f350 diesel dually
Truly a fucking joke!! I spent $60,000 on a truck with no engine compartment light!🤮🤮🤮
