C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
On hot days mine gives an alert that ASS has been disabled due to outside temperature. The A/C doesn't shut off. I'm in Phoenix.
Also if I'm in a stop/start situation, I just turn off ASS. I sometimes turn it off when in a parking lot. I leave it on for "normal" traffic.
I had originally planned to use Forscan to turn off ASS. I've changed my mind.
That is what I thought as well,plenty of things it needs to see before it will activate. No high temps in Seattle to worry about.
AZ_Liberty
2007 Expedition
I'm also in Phoenix (well Mesa). I've never got a disabled due to temp message. Just turns the engine off, then I reach over and hit the button.
Poppavein
WA
2024 Bronco
FWIW, there is no ASS in Sport mode. But you still have to respond with OK button when you first start up to stay in sport mode.
CalvinT
Calvin
2002 Subaru WRX Wagon, 2023 Badlands
I wonder why ours are different? I have a Badlands wiith the high package. Maybe that's why mine doesn't shut off. Does yours have an outside temperature sensor? Mine does.
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White & 22' JLURD
My solution, just on a much smaller scale.
AZ_Liberty
2007 Expedition
They all have outside temp sensors. It's far more obnoxious on the Wife's F-150 since the F-150 is an automatic and the Bronco is a stick so the implementation is a bit different.
Rumbloki
Alton
ATX
ZR2, 1973 Mach 1
I was looking for a hook to hang garments on road trips. Everything I found for the cargo area was mounted too low. The design of these handles allows a garment bag to hang without being folded up at the bottom. The flash makes the grips look grey in pics, but they are black.
Ford Bronco What's an EASY hack/fix that REALLY improved your relationship with your Bronco? 20240320_202646
Ford Bronco What's an EASY hack/fix that REALLY improved your relationship with your Bronco? 20240327_134121
Ford Bronco What's an EASY hack/fix that REALLY improved your relationship with your Bronco? 20240324_165819
Tork
Central Minnesota
1972 Bronco
Adding sport mode, ditching the double honk, redline hood lift supports,ford mudflaps before the first rock rash,rockworkx hard top tool less hold downs, self made rope shackles attached to the ring on the back of the rear seats for pulling the seats back to normal. And after a trip to Moab, lower shock skids, highly recommend. These all enhance the enjoyment! Have a great day!
swamp2
Russ.Cere
Lux Sponsor (Level 2)
Russ
Washington State
modcrate.myshopify.com
Mission Darkness Faraday bags for my key fobs when camping. Hated listening to the locks cycle.
*any faraday bag will due
Finbox
FL
KLR650
Great. Will probably buy today. I just can't stand ASS. Wait that sounds bad...
I do think panel removal is required though.
No panel removal on my 2023 Braptor. I could literally do this again in about 30 seconds.
swamp2
Fantastic. I was just looking/reading the Amazon description. I ordered. So sick of ASS... Thanks!
broadicustomworks
Hanging Rock, North Carolina
Oddly enough, one of the least expensive and least invasive to do things:
IAG rear soft top struts.
total game changer in every way.
