What width 35s?
bigbendsasquatch
Brett
georgia
2024 big bend sasquatch and 2024 black diamond
I’m likely going to swap the Goodyears on my BB Sasquatch to Ridge Grapplers. I know they have the same 315/70s, but I was looking at the 35s. They show a 11.50 and a 12.50. Stock wheel width is at the low end of the listed width for the 12.50s. Would either of them cause any rubbing issues or anything? Pros cons of each? I did try and search but I’m new here and still trying to refine my search skills on this platform. lol
RagnarKon
Ford Bronco, Escape, Focus
315/70R17 is roughly equivalent to 35x12.50R17. The exact size depends on the tire manufacturer, but generally speaking there is about 1/3" to 1/2" difference between the two, and both are considered to be "35s".
Edit— For reference...
  • 35x12.50R17 ≈ 315/70R17
  • 35x11.50R17 ≈ 290/75R17 (rare size)
raqball
Kris
WA
2023 Ford Bronco Badlands 2DR
Don't get me started on 315/70R17 not being 35's... :crackup:
Manufacturer specs are never anywhere even close to advertised when the tries are mounted and under load.
After the tires are mounted and under load a 315/70R17 will be about 33 1/4" and 35x11.5R17 comes in at about 34 1/4". Yes there will be minor differences across brands but a 315 is nowhere near even close to a 35" IMO..
Photos:
315/70R17
Ford Bronco What width 35s? thumbnail_IMG_2229
35x11.5R17
Ford Bronco What width 35s? IMG_0525
raqball
Kris
WA
I have 35x11.5R17 Falken Wildpeak AT4W on my Badlands 2dr on 17x8 wheels and I had to remove the front and rear crash bars.
RagnarKon
After the tires are mounted and under load a 315/70R17 will be about 33 1/4" and 35x11.5R17 comes in at 34 1/4"
Photos:
315/70R17
35x11.5R17
Oh yeah there is a big variance between tire manufacturers, and sometimes different tires within the same manufacturer are different.
Heck usually "36s" are closer to 35-inch in diameter than "35s". Tire sizes are silly.
bigbendsasquatch
bigbendsasquatch
Brett
georgia
I don’t have front crash bars. Not sure about rear. Could you post a pic from the front? Just wanna see how wide the tires look
raqball
Kris
WA
I have 1.75" Bora Wheel Spacers on mine to add additional poke. I am pretty sure I was getting rubbing w/o them..
I also have DV8 Fender flares on mine. These are a little wider than stock Badlands flares but narrower than the Sas Flares. I'd say the DV8 flares are in-between Badlands flares and Sas flares, width wise.
Here are a few images with the DV8 flares:
Ford Bronco What width 35s? IMG_0713
Ford Bronco What width 35s? IMG_0824
Here are a few images with the stock Badlands flares:
Ford Bronco What width 35s? IMG_0612
Ford Bronco What width 35s? IMG_0531
Oldhippie
Barry
Santa Cruz, Calif.
You should not have rubbing with any of those options (Sasquatch does not have crash bars)…the 11.50 is about an inch narrower and 10lbs lighter than the others with the 12.50 being slightly wider & taller than the 315…I am in the wider & taller is better camp but there are some folks who like narrow tires and/or care a lot about weight…in the end it is up to you…there are tons of tire choices out there and everyone has an opinion but few have much real knowledge…good luck
bigbendsasquatch
bigbendsasquatch
Brett
georgia
Looks good!
You should not have rubbing with any of those options (Sasquatch does not have crash bars)…the 11.50 is about an inch narrower and 10lbs lighter than the others with the 12.50 being slightly wider & taller than the 315…I am in the wider & taller is better camp but there are some folks who like narrow tires and/or care a lot about weight…in the end it is up to you…there are tons of tire choices out there and everyone has an opinion few have much real knowledge…good luck
so no issues with the 12.50 on a stock Sasquatch wheel?
jzweedyk
Moab, UT
2025 Lincoln Navigator
Like you never lied about "size". :blush:
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
Karsa
Calgary, AB.
‘24 Bronco Badlands
315/70 ~ load E @ 34.4x12.72” @ 70.8lbs
35x11.5 ~ load E @ 34.76x11.42” @ 66.3lbs
35x12.5 ~ load E @ 34.76x12.52” @ 75.52lbs
All three will fit, are load range E and are approximately 34.5” tall - the only real discrepancy is the weight, the 35x11.5 only weighs 66.3lbs, that’s a significant difference.
If you are okay with or even prefer a more narrow tire, seems like an easy bit of math?…
CrystalRedTintCoat
BertJ
Bay Area
12.5” width tire fits 8.5” wheel. Look up your tire specs.
See RIM Sizes:
https://www.goodyear.com/en_US/tires/wrangler-territory-mt/24362-79627083300000.html?back=tireFinder
https://www.mickeythompsontires.com/light-truck-tires/baja-boss-a-t
In the Mickey pages, find 17”, expand it. I’m looking at purchasing the 35x12.5/17 Baja Boss A/T with a D load rating with a tire weight of 69 lbs/tire. The stock Territory tires are load rating of C at a weight of 52 lbs/tire. I don’t think I need a load rating of E which brings the tire weight up to 71 lbs.
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
You should have no issues with fitting a 35 on a Sasquatch wheel. If you get a high load range tire, maybe, maybe, you'll get some uneven edge wear.
I when it's warm, and tire pressures are higher, I can see where the shoulders on my 315's (on stock BL wheel) don't contact the road. But I have an E load tire, to be expected.
I think tire width is preference. Some say pizza cutters are better for wheeling. I would assume a 12.5 floats better in soft terrain. Weight is also something to consider, but the 4.7 gears shouldn't have a problem moving big meats.
bigbendsasquatch
bigbendsasquatch
Brett
georgia
Yeah I saw that, and mentioned it in the first post. It’s just at the very minimum so I was curious if anyone had ever had any issues
