What lift do I need to run 37” tires on 20” rims
Kandace
Arkansas
Ford bronco
I have a 2023 badlands bronco with Sasquatch package and I’m not sure what I would need to run 37” tires on 20” rims without breaking the bank.
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
The width and offset are needed for an answer as they make a differencein where the tire will contact, the diameter of the wheel is useless as the tire is still 37" regardless of the wheel diameter.
atlawson
Tracy
Rose Hill, VA
Bronco 2022 Wildtrack Lux w/ Sasquatch
I have the zone 2" with 20x9 inch fuel blitz wheels with +1 offset and Toyo Tires Open Country A/t Iii
325/60R20. The tire inflated diameter is 35.4 and 12.8 wide.
Ford Bronco What lift do I need to run 37” tires on 20” rims 20230615_122641
ArkansasBronco222603
Kandace
Arkansas
Ford bronco
That’s what I’m trying to figure out what width and offset I will need to run in order to fit the wheel and tire combo I want
Stu10
Seth
Austin Texas
2022 Ford Bronco Outerbanks
I have a 2.25" RPG perch collar lift and 20x10 Fuel Rebels (-18 offset) on 37x12.5x20 Nitto Ridge grapplers (Outerbanks Sas 4 door). To get rid of all rubbing you have to do the full JKS max tire clearance kit. So far I have just removed the plastic pieces which got rid of all rubbing for daily driving but if flexing and going in reverse it does hit the metal brace in the front. When you do the full JKS kit you will cut that brace off and that should eliminate all rubbing for my wheel and tire combo.
atlawson
Tracy
Rose Hill, VA
I would like to add so far I have no rubbing.
Twister22
michael
lone jack,mo
2012 Raptor 1965 Mustang 1968 Mustang
I use the 3 inch Readylift. I used 17 x 9 1/2 black rhino wheels I think they’re +12+18 offset. 37 inch Yokohama MT. I’m just not a fan of big rims.
Ford Bronco What lift do I need to run 37” tires on 20” rims 9E4E52F0-3FBD-410F-8D32-2E02F72E52B5
