What if......
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Suppose you could build your bronco the way you want from the factory.......
Colors aside.....
1. Color coded mirrors, flares and handles (including sasquatch)
2. 2.7L paired to 7spd.
3. Marine grade vinyl and washout floors
4. 2doors........
5. Both lockers optional
6. Steel oil pan
7. Up/down tailgate w/power window
That's me. What do you have?
huey
kevin
Ontario & Kentucky
sounds great - make mine a 4 door and add a better top with finish options and a better interior light package
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
-Cloth seat option again
-SAS package with option for manual t-case.
-Analog speedo and tac.
-Non-$hitty hard top with sliding side windows
-Actual manual e-brake
-For ford to stop trying to over design things. Don’t try to be clever, try instead to be wise
-less crappy plastic parts.
-non turbo 6cyl option.
Butzy
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
- 2 door
- F150 Raptor seats
- V8
- the modular hard top we were promised
- soft close center console lid (that f**ker hurts if it falls and catches a finger)
- Drop down tailgate with swing out spare tire carrier
- bigger fuel tank
- a high beam indicator that’s not monochrome so it stands out instead of blending in to the rest of the monochrome
- higher towing capacity
- high pressure, rear facing water cannon to deal with tailgaters
CarmeloS
Carmelo
Central Jersey
2dr Coyote with Stick (T56 Magnum XL)
Standard 26 gallon fuel tank
Fully retractable soft top (like a Jeep)
MyColor footwells, Analog Gauges, door jams/handles, Cupholders
White and/or Red leather seats with Ventilation
Manual Handbrake
No safety features other than standard Traction/Stability/ABS
No A.s.s. From factory
More Amps in the Aux switches
2door
AA
2022 Bronco® The Sasquatch™ 2-door
C-Note
C
SC
22 Base
Speedometer that doesn’t look like it’s out of a bad video game
2 DR straight from factory with soft top, not a $2700 option with hard top.
equitasforall
