What engine will you be getting?
siddious33
Charlotte, NC
2011 Jeep Grand Cherokee; 2016 Dodge Challenger Hellcat
If the 2.3 was a Cast Iron/Graphite block I would get the 2.3; otherwise most diffidently I will get the 2.7.
If your head gaskets go out on the 2.3 you may have to scrap the block. For all you naysayers out there ask a Ford Mechanic and I do not want to hear that the aluminum 2.3 block does not warp... You may get luckily and not have to replace the block, but off to the junk yard for a wrecked Ranger for an engine swap. For what it was worth, I was so excited for the 2.3 until I found it had an aluminum block.
My wife had a Ford Edge as a work car. Started misfiring and throwing codes at about 80k on the odometer. Still ran though.
I was shocked when the service department called and told her the entire engine needed to be replaced. Apparently blew a head gasket and everything had to be replaced.
It was the 2.0 L engine, but still...
DrewBronc21
New York
2020 Subaru STi, 2024 M2
Aren’t the EB 3.5 and the Coyote as well as numerous built aftermarket “crate” motors aluminum blocks? Most of the built motors Ive seen are based on aluminum blocks and intended for high HP. I’m not too worried about it and if I end up with the 2.3, which I likely will because I want a manual Bronco, I will modify it and if the motor lets go, I imagine there will be built shortblock choices for Bronco as there are for the 2.3 EB Mustangs and Focuses.
Broncocito
B
NM
2021 Tacoma TRD PRO Manual
This is exactly what I am talking about. I just do not get why Ford would not go with the cast iron graphite block. The 2.3 is an incredible engine.
Broncocito
B
NM
They are, but they are not blowing gaskets at the rate of the 2.3 and nor are the blocks warping. Don't get me know, I want the manual too, but it appears if you want to squatch the Badlands we are forced to go with the 2.7.
aabsalon
Alan
Sacramento
Toyota Tacoma
You can get the Sasquatch with the 2.3 as well.
Broncocito
B
NM
I am not sure about that. I heard but not confirmed squatching the Badlands with the 2.3 and manual. Too bad they do not offer the manual on the 2.7.
aabsalon
Alan
Sacramento
Toyota Tacoma
I updated my response from a tweet from Mike Levine of Ford.
Broncocito
B
NM
I am so confused LOL
GYMEBronco22
Maine
F150, Focus RS
Getting the 2.7. Made the mistake of getting the smaller displacement engine in my current car and told myself I’d never make the same mistake again.
This! ^
I currently have both the 2.3 (2018 Focus RS) and 2.7 (2017 F150) engines.
The 2.3 is more then enough to move the Focus but it is highly strung and needs high revs to get the most out of it. Not sure its the best engine for a Bronco but I'm sure Ford know what they are doing....
Also, any 2.3 built after Summer/Early fall 2017 should have left the factory with the head problem sorted.
I have also just had a F150 3.5 loaner for two weeks (whilst Ford renewed the heads on my 2.7 F150...) and I must say the extra engine size was great. Whilst the 2.7 is OK in my 2017 it is definitely underpowered and needs to work harder at highway speeds. I am sure it will be great in the Bronco though.
2.7 Bronco for me..
edgeflyer
2013 FX4
I've actually driven a F150 with the 2.7L and a Ranger with the 2.3L and was impressed by both. Then read/ watched the Ranger reviews where the universal doubts about the 2.3L were dismissed with the first time behind the wheel.
I want the 2.7L because enough is never enough but the availability will dictate. The Ranger is rated to tow 7,500#, go drive one.
And we will be geared significantly lower. Something that seems to be forgotten alot.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
Always get the biggest engine. You'll never be sorry.
edgeflyer
2013 FX4
What? I'm a mechanic and this is irresponsible posting.
Hulkbuster19
Mike Moore
Ca.
chevy tahoe
2.7........BUT If the 3.0 does show up magically....I would have to check it out
Broncocito
B
NM
It is not irresponsible. If you have something to provide I am open to listen to you as you are a mechanic. You are saying there are no issues with the 2.3? Head gaskets, blocks, injection? Please convince me to stay with the 2.3. I noticed that "mechanics" love them or hate them.
Most people; including myself prefer an inline 4. Take a look at the Toyota 22r with 135hp with 35's and gearing can climb walls with 300K on the odometer. I am concerned on longevity and reliability.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
2.3/7mt...no regrets. 2.7 looks like 10lb of $hit in a 5lb bag to me!
