What drawers for 4 door?
agentdarnell
Jeremy
Tennessee
2025 Badlands sasquach
What sliding drawers do you use for your brinco? I am thinking of picking up one for recovery gear storage and possibly a place for my truck gun. I am also curious if you have full molle panels for the back and if the drawers fit with them.
contented
Karl
Central Fl
BMW M2 Competition
Jeremey, if I could offer one piece of hard learned advice, it would be carefully think through your long range plan. This saves conflicts further down the road. I.e., how do you use your bronco, what do you carry, do the size and shape of things you carry change? Do you plan on adding side molle panels, a mid level shelf or an attic shelf? Do you carry a frig and small battery to power it? I carry recovery gear in a M2M attic shelf.
Each of us has different preferences, needs, use case and how we like to pack. I don’t have drawers because they don’t work for me. I like flexibility and the ability to literally use every single cubic ft of space available. But, lockable drawers are a perfect way to secure firearms, etc. Our JK friends have drawers and love them.
I’m certain many will chime in. There are many different and well thought out storage solutions out there.
agentdarnell
agentdarnell
Jeremy
Tennessee
No plans on adding any shelves or fridge. I use my bronco as a day trip offroad currently as well as daily driver. I have a german shepherd that will eventually be abaervice dog that needs to be with me in the vehicle once trained.
I don't like clutter or overloaded vehicle. More hidden the better. I currently have a molle on the tailgate with a fire extinguisher, hatchet and med it and etool. I'll eventually get a small chainsaw to carry for off road trips and maybe a full size shovel, traction boards and other recovery equipment like kinetic rope, soft shackles, tree saver etc.
I carry an at15 with plenty of mags and a supressor.
SeptuagenerianSasquatch
Randy
Massachusetts
I use the Ford accessory cargo drawers--4 door only. It's also carried (perhaps made by?) Tuffy.
It's steel, pretty heavy--pay attention to your accessorizing, the weight ads up! Ratchet set is essential for install.
It has a pretty good lock, and the partitions are fairly adjustable. Depending on your firearm and how it breaks down, you could probably carry it in there. It could certainly hold an AR. The lock is good, and with your truck locked, should be safe enough. But note you'll lose access to your small tools compartment underneath your cargo deck.
Ford has been having 20% sales lately, keep your eye out, probably another one for our coutry's 250th !:clap::flag:🇺🇲☝
Ford Bronco What drawers for 4 door? 1781403033978-7l
Stillwater35
Stillwater MN
25 Green Badlands Sasquatch
I did just remove my broadict drawers. They made noise, were too shallow to carry anything helpful and added weight. I am looking at the arb drawers if anything because of the drawer depth.
An underrated value of a drawer is that with the top off and the car locked you essentially have locked storage.
Direvarg
Nicholas
Avon Colorado
2024 bronco
If you take apart the drawer and put a rubber weather strip behind the sliding drawer for it to press against when it’s latched, it should get rid of the rattle. Had the same issue with my American adventure lab drawers
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
contented
Karl
Central Fl
BMW M2 Competition
Jeremy, if I could offer one piece of hard learned advice, it would be carefully think through your long range plan. This saves conflicts further down the road. I.e., how do you use your bronco, what do you carry, do the size and shape of things you carry change? Do you plan on adding side molle panels, a mid level shelf or an attic shelf? Do you carry a frig and small battery to power it? I carry recovery gear in a M2M attic shelf.
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
I have the BroAddict TrailDeck and it works great for my needs, https://www.broaddict.com/?ref=gdqcukwg
Levels out the rear for when I fold the seats and sleep in the back, keeps some on board tools always ready. Depending on how an AR is set up, it might fit broken down, there are definitely some other options that would fit and with a custom cut foam wouldn’t rattle around.
agentdarnell
agentdarnell
Jeremy
Tennessee
I usually keep it in the case, but here is how its set up.
Ford Bronco What drawers for 4 door? received_1297353587596138
Ford Bronco What drawers for 4 door? 20240118_151407
Ford Bronco What drawers for 4 door? 20240516_120559
Ford Bronco What drawers for 4 door? 20240717_145311
