- MJ
- Jan 27, 2022
- 54
- 535
- 685
- Nashville, Tennessee
- 04 Xterra; 04 Element; 06 Sentra; 10 Rav4
- Badlands
I am looking for solid advice on what you use as a protectant on the hard top (especially) and other plastics such as the fender flares. I used 303 Protectant once on my hard top, but then stopped because the ingredients says it contains nonylphenol polyethylene glycol ether, I am not sure if these ingredients are a form of alcohol or solvent.
In certain light and angles, you can see honeycombing on my hard top. I picked up my Bronco 6/23. I noticed the honey combing within the first week after taking delivery. I can't imagine the honeycombing was caused by one use of the 303 protectant, but I have not used anything on my hard top since the one application.
From the manual
CLEANING THE HARD TOP
We recommend that you only clean the hard top in the following way:
Note: Do not use alcohol containing cleaner or any type of solvent on the hard top surface.
Note: Do not use power tools, paste wax or polish on the hard top surface.
Note: Do not use chemical solvents or strong detergents when cleaning the hard top. If any chemical solvent gets on the hard top surface, remove it immediately from the surface to avoid unrepairable damage.
From the manual
- Use a sponge to remove dust and loose dirt on the hard top surface.
- Wipe the surface with a soft, damp cloth and a mild soap and water solution.Dry the area with a clean, soft cloth.
- Make sure the surface of your hard top is dry before applying a small amount of conditioner or spray wax.
- For additional information and assistance, we recommend that you contact an authorized dealer.
