What are these ditch lights?
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
Modding newb here. I was gifted a pair of 3" ditch lights (previous owner didn't like the look on their truck and doesn't remember brand/specs). There are no labels/logo on the lights.
1. Do any lighting experts recognize these lights?
2. Wattage is unknown. So, I plan to route to AUX 1 / 30A yellow wire in the engine bay. Do I just need to buy some 60 AWG automotive wire to reach the AUX area?
3. The current wires are cut so short that they may not even make it down the gap behind the cowl mount area. Should I try to replace the wires entirely?
Ford Bronco What are these ditch lights? 20221002_162711
BroncoAZ
Mitch
Those look like some chinesium specials from Amazon. Personally I wouldn’t run them (especially in a pillar spot), but I’m a snob when it comes to lights. The unfortunate thing about cheap lights is that the beam patterns are generally unrefined, with the lights puking lumens in whatever direction is available.
Bronc6g22
Bronc6g22
Jake
Washington
Thank you! They feel surprisingly hefty (solid steel). You are probably right though. I'll look into other options.
Pseudoko
Vince
Chino, CA
My 2 Feet
also the previous owner cut the wires. usually there would be a connector at the end where you can just use a wire harness to plug it into. if your bronco has the aux switches which is appears that you do, wiring to the bronco is super easy. just go on youtube and there's plenty of tutorials so you can see what you would need to connect the wires.
8cam
Georgia
Corvette
For ditch lights you actually want a broad/shallow pattern which the Chinese imports usually have. Since you got them for free, I'd say go ahead and install them, if nothing else as a trial run. Can't hurt, and you'll learn something. As for the draw, I really doubt they draw all that much. I wouldn't waste Aux1/2 on them, those are for really sizable current draws like a full light bar or rear multi-power requirements. Hook them to aux 3 and see how it works.
‘21OBX
90Bronco19
2022 bronco outer banks
Use the heck out of them but I wouldn’t take up Aux 1. I’d throw a relay under the hood and use one of the lower amperage switches as a trigger. I run $23 Amazon lights with Amber and white. For something you might use 10 hours a year I can’t justify hundreds of dollars for a brand name.
BroncoAZ
Mitch
I went with Diode Dynamics SAE driving pattern in amber on my pillars. Something with a narrower pattern doesn’t light up the hood as much. I wanted something I could use as a high beam in Cape Cod fog.
Ford Bronco What are these ditch lights? DEA3609E-5CEE-48C8-8C65-837D7C8C95E3
Ford Bronco What are these ditch lights? DDF3E71A-1460-4D36-B3C1-EF08CFB26C1E
Ford Bronco What are these ditch lights? AD77AE70-CD8C-47EE-9114-48C47C8EA5FE
Ford Bronco What are these ditch lights? 757A738D-9432-43CC-9D01-63E7D23495E8
Ford Bronco What are these ditch lights? 5069DF0A-7575-4DEA-9725-0D176B6822F1
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Modding nube here. I was gifted a pair of 3" ditch lights (previous owner didn't like the look on their truck and doesn't remember brand/specs). There are no labels/logo on the lights.
Those are just some "amazon special" lights. Honestly, pretty much garbage. They'll do the job for you but won't focus the light anywhere and will rust within a few months and eventually get water inside.
They'll do the job for you now but honestly if you want a good set of ditch lights check out Baja Designs or Diode Dynamics: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
If you do decide to use those, get yourself a harness. THIS harness will work but you'll need to cut the plugs off our harness to give you a positive and negative wire to splice onto those lights: https://www.4x4truckleds.com/crystalux-a-pillar-wiring-harness-2x-wp-2-pin-connectors-baja-designs/
Bud2020
FL
Badsquatch 2.7 Lux
Ford Bronco What are these ditch lights? china-trump
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
0ne
Nate
CO
Flex
Use them as reverse lights?
rayhil67
Ray
Douglassville pa
22 2dr Bronco, 06 hummer H3, 01 SuperDuty F250
