- First Name
- Nels
- Joined
- Aug 14, 2020
- Threads
- 36
- Messages
- 2,060
- Reaction score
- 4,284
- Location
- Northern CO
- Vehicle(s)
- 2014 2D JK on 35’s
- Your Bronco Model
- Badlands
3000 chips per car? Dayum, let’s go back to 1970’s vehicles.
2 years ago when things got weird, I started reading all the car websites to find Bronco info to distract myself and stumbled across this article which has stuck with me ever since.
https://www.caranddriver.com/features/a32034437/computer-chips-in-cars/
I'd go back to manual roll up windows and manual seats and a basic sound system with just an AUX port for my phone if it meant saving a few thousand bucks.
My very first vehicle had power steering and that's it and I'd love to drive it just one more time.
Thats how we get a real bronco.Maybe we should all go back to riding horses?
The FE Edition has over 30 Modules. Here's the modules that I found in Mitchell:The boards are all part of the electrical assemblies. They are assembled outside MAP in another plant. If you ever have a chance to do a tour it will make more sense. The entire dash assemblies , seats, computers and harnesses are literally being unloaded from trucks as the vehicles are coming down the line. They will install the entire dashboard as a complete module, seats the same, engines the same, harnesses and computers the same. They are not installing “soldering” chips into boards in assembly.
It could be any of these modules that have shortages or a combination.
Below is an idea but even more modules with 4WD controls.
Yes.![]()
While electronics may make up to 40% of the cars cost, car companies are making a killing on these things. The actual cost of a lot of these electronics isn't much but the profit margin car companies make on these things is significant which is why they add them and why you'll never drive that no electronic car unless you buy a classic car.
This site could definitely use a spell check.Whether
Thanks. What is the material that you speak about and where does it come from?My machine shop works directly with semiconductor. We make the vacuum chambers for companies. These vacuum chambers are how the wafers are made. They need to be made in a vac sealed chamber. Any small particle that gets on these wafers will destroy it.
Part of what it killing the industry is our situation. We are incapable of keeping up with the business as are many other small shops that do this. The supply chain that everyone is very upset about stems directly from a material shortage that does not allow us to meet the delivery dates. We push for our material but our suppliers can only get us what the mills supply.
If the mill is late, we are automatically late. From there its a butterfly affect. Leaving anything that has a microchip at the mercy of the situation we are in.
Sounds simple, let the dealer install the missing modules. Then they become part of the manufacturing process. This probably opens up whole can of liability worms.its a good point. If there are some none critical controls like auto stop just deliver the bronco without and let the dealer add later. You probably can’t change back things to manual or other changes without basic design impacts.
Mitchell?The FE Edition has over 30 Modules. Here's the modules that I found in Mitchell:
BCM - BODY CONTROL MODULE
GATEWAY MODULE
DLC - REMOTE DATA LINK CONNECTOR
APIM - SYNC MODULE
IPC - INSTRUMENT PANEL
CTU - TELEMATICS MODULE
ETHERNET (GATEWAY MOD)
BJB - BATTERY JUNCTION BOX
PCM - POWERTRAIN CONTROL MODULE
ABS - ANTILOCK BRAKE CONTROL MODULE
CHCM - CHASSIS CONTROL MODULE
SIM - SWITCH INPUT MODULE
PSC - POWER STEERING CONTROL MODULE
AWDM - ALL WHEEL DRIVE CONTROL MODULE
SCCM - STEERING COLUMN CONTROL MODULE
OSCM - OCCUPANT CLASSIFACTION SYSTEM MODULE
PAM - PARKING AID MODULE
RCM - RESTRAINTS CONTROL MODULE
IPMB - IMAGE PROCESSING MODULE
ATCM - TRACTION CONTROL SWITCH
LDW - LANE DEPARTURE WARNING MODULE
TCU - TELEMATICS CONTROL UNIT
HVAC - HEATING VENTILATION AIR CONDITIONING MODULE
DDM - DRIVER DOOR CONTROL MODULE
PPM - PASSENGER DOOR CONTROL MODULE
RTM - RADIO TRANSCEIVER CONTROL MODULE
TTM - TRAILER TOW MODULE
SODR - SIDE OBSTACLE DETECTION CONTROL MODULE RIGHT-HAND
SODL - SIDE OBSTACLE DETECTION CONTROL MODULE LEFT-HAND
ACM - AUDIO CONTROL MODULE
WACM - WIRELESS ACCESSORY CHARGING MODULE
DSP - AUDIO DIGITAL SIGNAL PROCESSING MODULE
Yeah, Mitchell Pro Demand. The same info is also in AllData and is actually taken from the Ford Factory Repair Manual.Mitchell?
Could be. 3000 was from a average vehicle. A lot still. And they are used on boards way before assemble normally.This may have been posted here but I did not read through 5 pages to see, thought I would just post this for those who care to know useless information.
My salesman said he was just at a meeting and they were told there are 1700 "chips" in a new F-150. He did not say how many are in a Bronco but the point was just to put the "chip" problem in perspective.
What’s interesting is how they manage supply. Obviously a lot of decisions regarding which modules to allocate chips. This has to be made many weeks before build. I am guessing the one missing was intentionally left low inventory knowing it was possible to install after when needed.Yeah I had previously posted there are about 1400-1500 on an average vehicle per industry reports. 100,000 broncos to build …they only need 150 million chips to build them all.
