Vantrue N4 Pro Dashcam install in Bronco
BlakeD69
Blake
Range Rover Sport
In this 14 minute video I review the detailed steps to install a Vantrue N4 Pro Dash cam in my Bronco.
Many steps will apply to other dash cam's with front and rear facing cameras.
The N4 Pro also has a cabin facing camera.
Hope this helps you in your dash cam install.
00:00 Intro
00:29 Previous Camera Install (Windshield cracked)
01:01 Parts List
01:37 Tools Used
02:00 Trim Removal
03:19 Rear Cable Install
05:26 Fuse Box and Power Cable Install
08:00 Trim Replacement
10:30 GPS/USB Adapter Install
12:06 Rear Camera Install
12:58 Front Camera Install
13:38 Road Test
Enjoy your adventures on the road and in the mountains, woods, sand or where ever your bronco takes you.
Product links https://www.vantrue.com/products/n4-pro and on Amazon https://www.amazon.com/Vantrue-N4-Pro-Channel-STARVIS/dp/B0C3M7HPRT
Fordified1
Bob
Mid South Texas
I have 3 Vantrue dash cams. (RV, Bronco, F350) They work well.
BlakeD69
BlakeD69
Blake
Range Rover Sport
Are you having any trouble with the cameras shut off when the car does it shutoff at traffic lights. It was working fine and either due to a Ford S/W or Vantrue S/W update it started shutting the camera off when the engine does it auto stop/start routine ? It started happening two weeks or so ago.
Fordified1
Bob
Mid South Texas
Mine only work if they are getting 12v. so maybe your Bronco is trying to conserve battery. And I always turn off auto start stop so can’t help with that. Shut that shit off you’re wearing out your starter and if you have a weak battery you may get stranded at a stop light. Auto start stop is just more moronic EPA worthless crap.
BlakeD69
BlakeD69
Blake
Range Rover Sport
Thanks, I will try that
shimmy825
James
Los Angeles
2017 Mazda CX-5
OP - did you have any issues plugging the 5A fuse into a 15A slot? that's my concern
BlakeD69
BlakeD69
Blake
Range Rover Sport
