Rydfree
Benny
Alabama
Has anyone installed a rear dash cam on a soft top? Trying to decide between interior or exterior options.
I installed the Thinkware frt/rear camera from the Ford accessories website to the plastic housing around the rear view mirror. Instead of running the rear camera all the way to the back I simply dbl sided taped it to the rear of the front camera. It has a good field of view out all the side and rear windows. That could be an option that would work well
Ford Bronco Front & Rear dashcams installed with pics & links to products 20231003_181411
for a soft top.
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
rblock50
Ryan
Orange County, California
VW, Bronco
Oh wow, I just came across this seemingly cool dashcam. It basically replaces the existing black cover behind the rear-view mirror for a truly hidden camera.
https://www.stickerfab.com/products...021-bronco-mid-package?variant=46899966017855
It looks super easy to install, and has a rear-camera too, all for $248.
Ford Bronco Front & Rear dashcams installed with pics & links to products 1696535206322
It doesn't seem to have "parking mode" out of the box, but the site says to contact them.
I wish I would have seen this before I installed the camera that I have. Oh well.
Would be interested to hear if anyone installs this.
Jazer
Jessica
2.7 OBX
TRDFurgesson
Bobby
Mid Ohio
www.youtube.com
'22 2dr WT Lux, '22 Mach 1 HP, '92 Toyota 4x4 P/U
So I thought I had a great idea for my Vantrue N4 Pro 3 ch 4k dash cam install. Normal install of the front camera using the Dongar but the rear cam is on the left rear of the roll bar. I have a hard top but still wanted a cam when the top is off. It works perfectly.
TRDFurgesson
Bobby
Mid Ohio
www.youtube.com
Additionally, I ended up mounting my rear camera on the body itself. Slightly lower field of view, but doesn't get in the way of removing the hardtop.
I don't know if it would work as clean on yours though. Mine mounts from behind rather than above.
I did the same just off set to the drivers side a bit and directly to the plastic without issues. I have the RTR tire carrier that moves the tire up a bit.
Step
Stephen
Bronco6g08
Mariner
Any help appreciated. My redtiger dash am wonā€™t turn on using outlet inside center console or hardwire kit. It WILL turn on in the outlet in the rear cargo area and also in my wifeā€™s car. I really need it hard wired to access parking monitoring. I might have inserted the hardwire kit wrong but I think itā€™s all good. Not sure why it wonā€™t get power using the center console outlet either.
Lak34ers
Troy
Seattle
I installed the Ford rear camera to the plastic on the back of the roll bar and with the adhesive tape and making sure the spot is clean with rubbing alcohol it sticks really good no movement. Camera is light. Not sure why brackets are being used. Mine would be tough to pull off the plastic. Followed Fred's video on Youtube!
Step
Stephen
Bronco6g08
Mariner
OK I just got the hardware kit to work. I only had one fuse in the fuse tap instead of both. Next is running the wires but itā€™s already dark so that will have to come on a different day.
Bacon is Life
Powell, Ohio
OBX+Sas, 992 C2S
OP, you posted wrong product link - looks like Iā€™ll be returning. It should be a 16pin type A
Made the same mistake. I guess I should have read the entire thread before ordering.... and paid closer attention to the adapter and its vehicle compatibility. My bad. @JodyT , you may want to update your thread with the correct link.
JodyT
JodyT
Jody
East Texas
2023 Ford Bronco
Thanks for letting me know. I just corrected the link.
