Valve stem on Sasquatch wheels
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I don t have the biggest fingers in the world but man it is tough to unscrew the valve stem caps. Anyone using extenders or just forgoing caps? I was using my own compressor hose today and it is just tough to unscrew the female end quickly as the wheel ring gets in the way. I ended up over inflating by 3-4 pounds just to allow time to unscrew the compressor hose.
OG-Surfdog
Princeville, Kauai, Hawaii
www.the65falcon.com
'65 Falcon, '74 TR-6, '13 F150, '21 Mach-E
Same.............. went through several versions.
Some rusted horribly, finally settling on some brass ones found on Amazon.
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
I got this for $14 on Amazon. Well made and I don't have to unscrew it with cold, fat fingers anymore.
Ford Bronco Valve stem on Sasquatch wheels Screenshot 2025-12-28 154232
BroncocnorB
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I ordered them thanks
Bschurr
NY
I would STRONGLY suggest to not use anything but plastic/rubber to cover or (“permanently”) extend valve stems due to dissimilar metal corrosion which could be a significant issue trying to remove them… YMMV
Climber
Paul
Wisconsin
Chevy Colorado ZR2 Bison
Only plastic caps.
E. J
Kentucky
Ranger Raptor
Same difficulty with the RR wheels. My plan is to use a die grinder and remove material from the deco ring for easier access to the valve stem. I'll post a picture once I'm finish.
E. J
Kentucky
Ranger Raptor
Opened up the clearance around the tire valve stem today. It is easier to get the Speedflate chuck off the valve stem now. Here's some pics.
Ford Bronco Valve stem on Sasquatch wheels IMG_20251229_115740438_HDR_AE
Ford Bronco Valve stem on Sasquatch wheels IMG_20251229_130926470_AE
Ford Bronco Valve stem on Sasquatch wheels IMG_20251229_132531339_AE
Ford Bronco Valve stem on Sasquatch wheels IMG_20251229_132853959_HDR_AE
BroncocnorB
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
That’s awesome. Thanks. I might b using the dremel we’ll see after I get the quick disconnect. I don’t air up and down a lot but was at 32-33 psi and doing a long drive to the keys next week.
