Using upper dash USB port to run Android Auto?
Mkohler30
2024 Bronco
Is there a way to get the upper dash usb port to run Android Auto?
freebob
bob
michigan
2022 bronco
Yes you can.You will have to remove the radio . Then switch a few usb plugs/ wires. around..Its alot of work..
Mkohler30
Mkohler30
2024 Bronco
I may have to try to do this and then write up a how to....
freebob
bob
michigan
2022 bronco
I know you can I did it back in 2021 .I just switch the one from the console.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
What's the benefit over using bluetooth?
Mkohler30
Mkohler30
2024 Bronco
From my understanding you have to be plugged in to the vehicle to use Android Auto.....it doesn't work over Bluetooth
JerryC
Memphis
2022 Bronco
Bluetooth works and it also works wired.
The Bronco Sport had to be wired, but I don't know if they fixed that.
RagnarKon
Ford Bronco, Escape, Focus
Yeah @JerryC is correct.
  • Sync 3, which is the current version on Bronco Sport, requires it to be wired.
  • Sync 4, which is what the Bronco has, works wirelessly.
Your version of Android on your phone also matters as the initial release of Android Auto was wired only, but I'll admit I don't remember version details off the top of my head.
Bullitt
Colorado Springs, CO
2022 Bronco, 2001 Bullitt Mustang
No need to do anything to the top usb port. You have wireless Android Auto and it auto-connects when you're not using the lower USB port.
Mkohler30
Mkohler30
2024 Bronco
That's just it my Android Auto won't connect through Bluetooth it tells me to plug in my phone.....is there a setting that I'm missing?
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Sync tells you to plug in or your phone tells you to plug in?
Mkohler30
Mkohler30
2024 Bronco
Sync tells me to plug in the phone for Android Auto
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
It can connect to more than one phone for calls but only one at a time for AA.
You have to tell Sync which phone to use AA on in the Phone List by highlighting the AA icon.
Did you do this step? Is you phone and AA up to date?
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
Mine works over Bluetooth, it also automagically turns on WiFi on the phone, must need more bandwidth...
