Using LockNLube air chuck with ARB Digital Inflator
desibull
Mahesh
Chandler, AZ
BMW 335i
Hello:
I am looking for some advice on what I am doing wrong. As some folks have experienced the air chuck that comes with the ARB inflator just does not seem to work; I seem to have to keep fiddling with it and hold it as I am inflating my tire to ensure air is not leaking; never seem to get a tight seal. Many have recommended the LockNLube air chuck. I initially mistakenly got the closed flow kind and then ordered the open flow one but even that does not seem to work. It does not thread all the way into the ARB inflator as seen in the pic. Do I need to first wrap the male end with some tape? Am I using the correct chuck? Is it even worth it or should I just return it. LOL!!
Thanks a bunch for your help!
Ford Bronco Using LockNLube air chuck with ARB Digital Inflator IMG_1855
desibull
desibull
Mahesh
Chandler, AZ
BMW 335i
Sorry for the late response but there is air flow...just leaking at the joint because the fit is not snug I guess. But it is the same issue whether I used a closed or open valve.
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
Teflon tape is a requirement. (Or some other thread sealant.)
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
Yes tape, but the thread pitch may be off too. Metric vs NPT.
desibull
desibull
Mahesh
Chandler, AZ
BMW 335i
I confirmed the ARB inflator uses NPT
Species8472
CO
2025 Bronco Badlands Sasquatch
Here's a video of how to put teflon tape on your hose fittings:
