recommendations on a tire inflator
Status
Not open for further replies.
atjurhs
Todd
Huntsville, AL
2024 Bronco
what are your recommendations on a tire inflator? i just got an OBX and my current tire inflator won't connect to it :(
SunilD
San Diego, CA
2024 Bronco Wildtrak
I saw a video about this inflator from Apex Designs. The product wasn't available at that time. I'll probably get one now :)
The inflators are "tuned" to work accurately at low tire pressures unlike a more typical one. It also has a vent to calibrate it when elevation changes.
https://www.apexdesignsusa.com/products/precision-tire-inflator
atjurhs
atjurhs
Todd
Huntsville, AL
2024 Bronco
what do you guys think about the Etenwolf Vortex S6 ? YouTube videos show it to be a really good machine.
MNBigfoot
MN
How often are you airing up and down? I'm a fan of the Milwaukee M18's or a VIAIR 400P
People seem to like @Tricky Mike inflators if he's still selling them.
Felix808
SRV CA
A lot has to do with the size tires you intend to inflate & the type of set up 1,2,4 tire setup.
The the twin compressors move a lot of air but can deadhead and damage the compressor if they can't move the air due to restriction. 🤠
Dougpaw57
Doug
Olympia, WA
2024 Bronco 2DR
Roger123
Roger
VA Beach, VA
I'm a fan and user of Viair products. Very well made and several options depending on your needs.
Glade Runner
Everglades
VA
Yes
Everglades
Dougpaw57
Doug
Olympia, WA
2024 Bronco 2DR
I watched that video before buying.
If note, I said basically the same, not ”the same”.
For those interested, go to 25:18 in the video where you will learn both units come from the same manufacturer along with the differences.
The aluminum compressor cylinders and braided hose on the Morrflate are worth their weight.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
All-Top from Amazon.
2 years running strong, through multiple winters. Fast inflation.
Status
