Using locked Procal to change tire size on different VIN?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Can I use my old Procal module that the tune is VIN locked on my 2021 to change the tire size only on my 2025?
Subsequently, can I use the Procal module to view gauges, change gearing, etc? Is it just the tune that is lock or is the module itself a paperweight now?
I couldn’t find the answer to this online. I guess I can call Ford Performance?
redone17
redone17
Cold Spring, NY
Plug the damn thing in and find out.
Haha! I would, but it’s at the shop getting the tires mounted. Just planning ahead.
I’ve made some Forscan changes - but, I think I read that the tire change sequence isn’t working yet for 2025.
redone17
redone17
Cold Spring, NY
It won’t let you. I tried once
redone17
redone17
Cold Spring, NY
My ProCal is from the first year or so. I never updated it either because I didn’t want to lose Rev Match/ASS.
redone17
redone17
Cold Spring, NY
YMMV. Forscan should be able to though
Ford Bronco Using locked Procal to change tire size on different VIN? imag
Ducati1098
Maybe it does have something to do with the VIN lock then. I just assumed it didn’t, because a procal by itself without a calibration can do tire size recalibrations. But apparently once a procal has been used with a calibration, it VIN locks all the features.
@redone17 you should be able to easily contact Ford performance and they can send you and unlock code. From what I remember they normally don’t charge for this if you purchased it for a previous vehicle.
crenca
Southern New Mexico
As someone mentioned, Forscan can make this as well. Given what else you can do with Forscan it might be worth getting into if you are not already.
redone17
redone17
Cold Spring, NY
I thought I read that people were having issues with tire size and 2025. Maybe that’s changed?
redone17
redone17
Cold Spring, NY
Ok, I just got my truck back. I’ll report back. Thanks.
