USB Ports max rating
sportcoupe
Georgia
2023 Bronco
The owners manual says there are two fuses for both USB Smart Charger 1 and USB Smart Charger 2.
Charger 1 is 10 amp fuse
Charger 2 is 5 amp fuse
Which USB ports are on the 10 amp fuse? Which USB ports are on the 5 amp fuse?
MadMan4BamaNATL
Ray
Atlanta
I’d imagine the USB C port has the higher amp rating, if that’s what you’re asking.
sportcoupe
sportcoupe
Georgia
2023 Bronco
Pull the fuses one at a time and see which ports stop working.
I was hoping to avoid actual testing and get the spec online. I couldn't find the data unless I had access to the wire diagrams, which I don't. So.... I tested.
Charger 1 - 10 amp fuse removed disabled all USB's, the C and the A throughout the vehicle.
Charger 2 - 5 amp fuse removed, all USB's are still working.
USB C and USB A are from the same 10 amp fuse. See above test.
What does the 5 amp USB Charger fuse power?
Isn't there one for the back seat, on the rear of the center console?
sportcoupe
sportcoupe
Georgia
2023 Bronco
I tested the USB C and A ports on top of the dash, below the radio in center console and at the rear of the center console in back seat. They are all on the same 10 amp fuse.
Pulling the 5 amp fuse had no effect on any port.
Ford Bronco USB Ports max rating 1720891397815-h4
Ford Bronco USB Ports max rating 1720891343634-62
Maybe the wireless charging pad then? Not sure
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
That would make sense, at best it's a Qi1 charger, and would only draw 7.5 watts.
I have a measuring device, been meaning to see if any of those ports kick up to 9V or 12V charging speeds or if they're stuck at USB's old 5V standard.
They all charge butt slow, even the USB C one. I haven't checked any of them but I would not be surprised if they are all the old 5V standard.
MadMan4BamaNATL
Ray
Atlanta
Really? That’s pretty slow. Only other I can think of is the one on the top of the dash to keep a camera charged.
CalvinT
Calvin
Phoenix, AZ
According to the wiring diagram, it's the overhead console. But I don't think there's a USB port in the overhead console. Since the Bronco shares a lot with the Ranger, maybe Rangers have a USB port there. Fuse 139 just slipped through the cracks.
So it's probably safe to treat F139 as a spare 5A fuse.
CalvinT
Calvin
Phoenix, AZ
Thinking a bit more. I bet the wire is there (overhead console). It's just not connected to anything. So maybe the wire could be used for a camera or radar detector?
CalvinT
Calvin
Phoenix, AZ
Did a bit more research. This page shows where all the USB ports would be. Maybe when I'm feeling energetic, I'll pull the cover off the overhead console and see if there's an unconnected brown and white wire (BN-WH). It may go into a connector and not come out the other side.
CalvinT
Calvin
Phoenix, AZ
StickerFab
Fort Myers
www.stickerfab.com
2021 Bronco Badlands / 2023 Bronco Raptor
USB C port on the dash has a higher output than the lower ports. My cables have a little LCD with the output power in watts. A little too dark right now to capture a photo.
