BroncoBrook
Brook
L.A.
21 Bad Squatch
I know that there are at least 7 threads on the subject, but I'm not finding what I'm looking for and maybe it just doesn't exist.
I am looking for BIGGER that 4" ROUND pillar lights that are either both white and ember, or white with an option of attachable lenses, and the unicorn part is a running light feature.
https://www.oraclelights.com/produc...-round-post-mount?_pos=1&_sid=e7525d08f&_ss=r
This is the closest I could find to what I'm looing for, but these do NOT have a FULL ember option, just the runners are ember. If these had an attachable ember lense, by search would be over. Unlike the Ridged option, these do not come with "EVERYTHING YOU NEED" so would have to scouer the for the proper wiring. I'm a "hands on guy" but not an electrical expert. Wouldn't know what gauge wire to use to make my own.
My ultimate unicorn lights would be:
Larger that 4"
If I had to choose, I would lean ember
Running light feature a plus.
And a side note: Brackts that fit stock anchores, left bracket with antana mounting hole and light hole and right hand side just light hole. Another unicorn to add to the corral.
Any help finding these horses with a horn would be greatly appreciated.
BUCKIN6VA
Rob
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
PWillette
Parrie
Maine
Larger that 4"
https://auxbeam.com/collections/5-inch-led-driving-light
broadicustomworks
Hanging Rock, North Carolina
I agree with @BUCKIN6VA on the Gravity Titan. I have the Pro6's and like them, wish I had held out and bought the Titans.
As far as your mounting brackets go, you are just going to have to have an open slot on the one side or just single-light brackets.
No one sells a set of dual for one side and single for the other.
OR buy one set of each for double the $ and use what you want, try and sell the others for whatever you can get to recoup some of the cost.
Chrome_Pony
Chrome
The Great Land
@Baja Designs LP4/LP6 has an amber lens cover
Ford Bronco Unicorn Pillar Lights help 1737574943116-qq
KC Hi-lites has the Slimlite LED that has an amber cover
Ford Bronco Unicorn Pillar Lights help 1737574996893-5x
KC also has the Gravity/Titan with an amber lens
Ford Bronco Unicorn Pillar Lights help 1737575093456-4z
ARB Solis has an amber lens cover.
Ford Bronco Unicorn Pillar Lights help 1737575217376-az
Probably need a bracket set to clear the antenna for a ≥ 4" LED light... unless you unscrew it and toss it like I did.
BroncoBrook
BroncoBrook
Brook
L.A.
21 Bad Squatch
Diving into all your suggestions. Thank you to everyone so far. Much appreciated!
SPVPARTS
Lux Sponsor (Level 2)
Greenwood, IN
specialtyperformanceparts.com
Ford Raptor/Bronco/Mach E
@BroncoBrook,
We have several options available that check all of these boxes, but I'm think the Baja Designs LP-Series may be the best option for you and will certainly be the most powerful.
We can do this a-pillar kit with LP6's (6" lights) instead of the LP4's (4" lights) if you are wanting them larger than this. In the below link you will find pictures, as well as a video on the page that shows how they look and fit with this new modular a-pillar mount we made for the Bronco.
SPV Parts 2021-2025 Ford BRONCO (Including Everglades) Modular A-Pillar Light Kit with Baja Designs LP4's
(Again, the listing is for the LP4's, which is what is depicted, but we can do the kit with the larger LP6's if you'd prefer.)
The Baja Designs LP-Series lights have the following features:
* Choice of Clear or Amber for the main light
* They all include the amber backlight
* They come in 4", 6", or 9" sizes
Further, our patented plug-and-play wiring harness system makes install a breeze and our Headlight Adapter Harness allows you to put the amber backlights on with your running lights automatically, which means they also will function like your OEM lights when using the key fob and opening/closing the doors.
If you look at this video around the 1 minute: 44 second mark, you will see him demonstrate this function with the key fob when our backlight harness is connected:
SPV Parts YouTube Channel - Bronco with Rigid Lights and Backlights
If this sounds like something you are wanting, please feel free to call or text me at 317-934-6778 and I will gladly assist in any way possible.
I hope to get the opportunity to assist you with your build!
Have a great day!
Sidney @ SPV Parts
317-934-6778
[email protected]
Red Five RN
Jeffrey
Oklahoma
Ford Bronco Wildtrak
Did you go with the LP 6? Or did you choose another light pair? I’m curious what you chose as I’m debating between XL 80s or LP 6 for the A pillar position.
SPVPARTS
Greenwood, IN
Hey, Jeffrey.
If you want to compare and contrast between those options, feel free to call or text me and I can help you with figuring out which will be best for your needs and circumstances.
I'd be happy to help in any way I can.
We are currently running a sale on all of our front-end light kits for the next week (until 7/31) with the code SPVSUMMER, so it's a great time to save some extra money, too.
Just let me know if I can help with anything.
I hope you have a great day!
Sidney @ SPV Parts
317-934-6778
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Larger that 4"
Not a unicorn at all.
Check out the Baja Designs kit we offer. The XL Series lights are what you want
Our kit has them as SQUARE but if you simply add a comment that you want ROUND bezels on your order, we would be happy to put the round bezels on instead.
They are not a dual light but you can get the whit and then throw amber covers on (yellow actually)
Now with the XL lights, you DO need to add our mounting bracket otherwise the radio antenna gets in the way because the light is 5" or so.
But here is the kit: https://www.4x4truckleds.com/baja-designs-a-pillar-kit-for-2021-ford-bronco-w-kr-off-road-brackets/
Here are covers in case you decide to get a white light but then want amber (yellow) covers for them: https://www.4x4truckleds.com/baja-designs-xl-r-rock-guard-amber/
Looks like this (this is an example)
Ford Bronco Unicorn Pillar Lights help 1753394450942-rm
4x4TruckLEDs.com
Adam
Lindenhurst, NY
