Under seat powered subs?
Cruiser
Andrew
Washington Mo
Bronco, Audi S5, BMW X640i
Looking at kicker under seat powered sub. Has anyone tried one, and do they even fit?
KABQ
Aaron
Albuquerque, NM
I have an HS10 under the driver's seat of my base 2-door. It fits, but hangs out behind the seat a bit. This is fine for me since I almost never have anyone in the back.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I have a JBL BassPro Nano under my backseat. It’s installed at an angle to fit, and can’t put one of the seats down, buts it’s a quick unplug to do so when needed.
TXscooterguy
Dennis
Bedford, TX
1969 Corvette Convertible
I have the Kicker 8 inch powered sub under the driver's seat. I love it.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
From what I could tell, really getting the Kicker HS10 under my seat required seat jackers...don't want to do that.
Right now, it's wedged under the back seat and fits pretty well, definitely not going anywhere! If I need to put the seat down I can still lay it flat. I had looked at several other mounting options but this is the most flexible for my use.
Bonus...after a year of having it in various positions in the trunk, it does hit harder here.
Ford Bronco Under seat powered subs? PXL_20250213_145827764.RAW-01.COVER~2
BroncoOB
Texas 2 California
Toyota Sequoia, Tesla
I have my Kicker in the trunk area and put a trunk cover over it. This thing has a kick to it.
jdbabb4247
Wernersville, PA
2022 Ford Bronco OBX
I put an Infinity sub, from Crutchfield, under front drivers seat, replaced 4" speakers with 4" Pioneer, put Dynamite in speaker pods, sound is excellent!
Mjasi3
Chicago
Everyone… Are these hooked up to the BO system? I like this idea of an all in one, and I don’t need to rattle the windows.
pic? Manual or powered seats?
Thanks all.
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
This one of those - "you'll have to look" questions. There are so many different seat options on the Bronco, 100 people could answer "WORKS GREAT - GO FOR IT" yet you might find that, it actually doesn't work at all.
Then there's also the "fits almost, but good enough for me" factor. Of course, "good enough for me" means something totally different for everybody.
Personally, I've not tried it. But I've looked - and there is very little room under my seats. Might could make it work - but not high on my personal list of mods at this point in time.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Thanks all.
No B&o system here, I bought the plugnplay kits hs10, wiring harness and key200. 4 amp
KABQ
Aaron
Albuquerque, NM
Manual seats only in the Base. It won't go any further under the seat because of the vents under there, even if I raise the seat.
This is definitely a case of "it fits good enough for me" as @Figmo mentioned. Also, ignore the wiring, I just haven't gotten around to cleaning it up yet.
Ford Bronco Under seat powered subs? PXL_20250213_231623955
Mjasi3
Chicago
Thanks!
BigMeatsBronco
Allan
2021 FE 2 door
I have TWO of the kicker 10s, one under each front seat, I did build/use 1.25 risers with a simple coupling nut...heres pics. sounds great plenty of low end bass now. What REALLY sounds best tho is the HUGE (deep) speakers I shoehorned into the kick panels... they are the JL Audio 6W3v3-4. connected to a soundstream amp. sounds FANTASTIC.
Ford Bronco Under seat powered subs? 20250221_090507
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
I figured you might show up here. I didn't wand to do the 1.25" risers as it is so easy to get in/out now...but man, with a lift like that, why not!?! Truck looks good and I bet sounds better.
