Lars31177
Frederick, MD
2016 Lincoln MKC, 2019 Tesla M3
Hooked then to the upfitter switch (my last one left 😞) and I use the remote for the color change. There’s memory, so whenever I turn the Upfitter switch on, the lights are the last color I used.
keep talking dirty to me. That's exactly what I wanted to hear... thank you.
Jazer
Jessica
2.7 OBX
False alarm. This is not Area 51.
PghBronco
Pittsburgh
These are the Opt7 Photons. I liked them as they are magnetic so an easy install.
Im not a fan of rock lighting... I am a HUGE fan of Opt-7 products. I had their Flux beam LED/HID bulbs. The brightest light i have ever seen. I would be getting flashed (not the good "flash") couple times a week. Then id flash back... bright to brighter LOL. Then I installed their Aura motorcycle lights on my bike.. Very bright and id recommend op7 products to anyone.
Can you show the actual light pod? im curious to see its construction. DId you wire these into the upfitter switches?
Potluck99
Potluck99
Las Vegas
1969 CJ5, 1977 J10, 2022 Lowrider ST
page 1 of this thread has some photos of the pods and mounting- I did hook it up to the upfitter switches. I’ve used op7 in the past and for certain applications they are great. But I’m a huge Baja Designs fan for any real purposeful lighting. And like you- it even transferred over to my bike- I put the LP6 as my headlight.
Ford Bronco UFO Bronco Landing? 4D1FD357-7550-4079-84F5-AAB730A6ED86
PghBronco
Pittsburgh
Nice,
My b, I didn't scroll down far enough on the first page.
Spencer
Philadelphia, PA
C63 AMG, CLA 250, TrailBlazer
I have to say this is one of the most useful, awesome and authentic threads I have ever read. No haters/complainers here. Just enthusiasts and people with a sense of humor.
I appreciate the different types of lighting that people like. Some folks want super bright lights for illuminating the way ahead on a level that is not outdone by anyone. Others prefer lighting that accentuates the aesthetic of the vehicle. While some night time rock crawlers may say they need wheel well lighting for wheeling, they are inevitably white. The addition of hundreds of digital colors is for another purpose.
Potluck99, I salute your awesome rock lighting. I didn't even know that magnetic mounting was an option. I thought it was either you go 3M sticky options, or you drill into the inner wheel well guards. So thank you for that, because the magnetic option makes so much sense.
I will say one thing that Neko asked about on page 2, which is how many kits were you running?
I'm a believer in 2 lights per wheel well for the best coverage, since it's hard to find a convenient place that illuminates the entire circumference of the wheel well uniformly. You managed to do such a good job with one light per wheel that Neko had to ask because he wasn't sure.
To newbie amateurs like me, I might recommend 8 lights total. There are videos on how to drop the wheel well covers.
Lastly, I'm going all in with Oracle Bronco illuminated grill lights.
https://radco.com/ford-bronco-white...vFBwdT4tDxSC0yVO-1dAP96kTRSyDgcRoC7xoQAvD_BwE
I'll share pictures once I actually get a Bronco to install them on.
Happy Illuminating
Kcmojoe76
Lees summit
Nothing
Just got my opt7 kit. Going to try the install tonight. Where did you mount the control box, and how did it tie to your switch? Sorry for this if it is a dumb question. Just trying to save myself some time and headache
Kcmojoe76
Lees summit
Nothing
Also, any idea what this is for? Should I drill a hole and run the cables through to get to the aux switch and fuse box?
Ford Bronco UFO Bronco Landing? 20220930_213013
Ford Bronco UFO Bronco Landing? 20220930_212800
Potluck99
Potluck99
Las Vegas
no need to go thru the firewall.
Ford prewired leads to areas in the bronco (above windshield, rear cargo, front grill, glovebox..)
Then the leads to the six upfitter switches are all together at the firewall near the fuse panel. Each upfitter switch has a different colored wire and amp rating. I would use aux switch 6 (yellow w/orange stripe) as it’s a 10a. You can zip tie the op7 control box to the harness in that area as well.
Ford Bronco UFO Bronco Landing? BFC26FB6-56E1-474F-84CF-443D0DB74A02
Ford Bronco UFO Bronco Landing? BB1ACE1C-E40F-4A2E-9339-30766A42F9BA
Potluck99
Potluck99
Las Vegas
see above- also the 6 leads from the upfitter switches already have fuses/relays. So you just need to hook up the positive wire from the op7 to whichever lead you use, and ground the other wire and you’re good.
Neko
Derrick
Pratville AL
2022 BD 2-door
Asked a few questions last week, made the purchase and installed today. Really easy install and used uplifter switch 6. Went with the aura opt7 with Bluetooth and mounted above the tires drilling into wheel liners. Routing the wires, mounting, and electrical was a breeze. Did not have to remove any of the wheel liners. Pics to follow when it’s dark. Appreciate the write up and idea generated by @Potluck99
228R0NC0
Ryan
22 Bronco Wildtrack, 21 Dodge Ram Rebel, '66 Stang
@Potluck99, awesome job. Liked it enough to already buy one.
Question I have is how did you run the wires from the rear to the harness/fuse box area (fronts are pretty self explanatory)? My understanding is you ran them all to the engine bay under body and then tied in there, right? Any pics would be awesome (understanding I’m a 4-door vs 2-door).
Thanks!
Potluck99
Potluck99
Las Vegas
I followed the harness that is attached to the frame rails. I zip tied the opt7 wires to that.
