Turn signals as DRL base model
c_walters
Mooresville, NC
2023 Bronco OBX
Playing around with forscan the other night in my 25 base. I’d like to run the turn signals as DRL’s with the low beam off. Couldn’t figure it out, anyone had any luck?
Got global up to work, took a few try’s to find them in every folder. Looking to remove the fake engine noise and see if it’s possible to remove the “folders” on the right side of the radio display, anyone pulled that off?
I think they are called "position lights" in Forscan -- but be careful, I was running like that for a while, and the turn signals wouldn't work at all with the headlights running - just with the DRLs, oddly enough.
johnk135
Chicago
25 Bronco Big Bend / Black Diamond
Have you tried just turning your parking lights on and driving that way? You have to switch back to off or automatic when you park.
NC_Oak
2024 4 door 2.3 sasq
you have to be in park (with daylight sensed) for them to be on. done through the bdycm module. don't need the as built way when I did it either. you just select it. I can't recall the language right now but if you scroll through you can find it.
