Forscan question about turn signals
Abdiel
Phoenix AZ
2024 Ford Bronco
Everglades
Question; on the Ford Bronco, when one short-presses on the left/right turn signals the turn signal then flash 3 times to indicate to oncoming traffic your intention to make a left or right turn .
Is there a way in Forscan to change / increase the 3 short flashes to 5 flash?
B22-2023
Houston
abdiel.villalobos
Abdiel
Phoenix AZ
2024 Ford Bronco
Everglades
Thanks, I’ve been going through the spreadsheet and all the other comments have not been able to find something specific on turn signals.
I did find a YouTube video from this channel “Ricardo’s Workshop”, where he explains how to do it on a Ford F-150, I just don’t know if it will also work on a Bronco!
this is. What he did:
Change Turn Signal Flashes: SCCM 724-01-01 xxxx-x*xx-xxxx
0= 1 flash
4= 2 flashes
6= 3 flashes
8= 4 flashes
A= 5 flashes
C= 6 flashes
E = 7 flashes
Now, I tried this changing it on mine to “C”, but nothing happened.
Any feedback on this would be appreciated!
abdiel.villalobos
Abdiel
Phoenix AZ
2024 Ford Bronco
Everglades
Okay, I found the mode on the spreadsheet you originally mentioned, thank you. I think that the first time I looked at it I didn’t pay it any attention because it was all crossed out!
any way, im going to try it tonight when I get home and see if it works!
thanks John!
Bobio
Bobby
United States
2024 Bad lands
thanks John!
Let me know if that works pls.
Go_UL_Cards
Wyatt
The Villages, FL
2024 4 Door Soft-top
I set mine to A = 5 flashes - no change. I still get 3 flashes.
Mjasi3
Chicago
thanks John!
Was anybody able to get anything other than 3 blinks to work?
Roundboy
Vermilion, Ohio
2025 Badlands SAS
I am still trying to change my turn signal from 3 to 5 flashes when you short press the turn signal. I think my 2025 Badlands SAS can not be changed. Any help is appreciated.
Mjasi3
Chicago
wasn't able to do it on '24 Wildtrtak
Roundboy
Vermilion, Ohio
2025 Badlands SAS
Well let's try this one. Can we disable the 'Keep Hands On The wheel' warning. I Get the warning when I drive on the highway for some time because my hands are not at '10 and 12'. It is very annoying.
ReactiveD
Derek
Citrus County, Florida
2025 Bronco OBX, 2024 F150 Platinum, 2015 Mustang GT
Was anyone able to go through the Easy Mode to change the turn signal count?
