Trouble Upgrading My Bronco with Procal4 - Need Help!
brockbrock
brock
raptor
bronco
Hello fellow Bronco enthusiasts,
I recently purchased a Procal4 for my Bronco, and I'm having some issues with the upgrade process when connecting it to my PC. I was hoping to get some advice and insights from the community here.
Issue: When I connect my Procal4 to my PC, I am unable to perform the upgrade as intended. The software doesn't seem to work as expected, and I'm at a loss as to what might be causing the problem.
What I've Tried So Far:
I've followed the instructions provided with the Procal4 to the letter.
I've ensured that my PC meets the system requirements.
I've checked for any driver updates, but everything seems up-to-date.
I've attempted the process multiple times, but with no success.
Questions:
Has anyone else encountered a similar issue with their Procal4 and PC connection?
Are there any troubleshooting steps or tips you can share to help me resolve this problem?
Is there any specific software or firmware I should be aware of to make the upgrade smoother?
I appreciate any guidance or advice you can offer. Your experience and expertise will be invaluable in helping me get my Bronco up and running with the Procal4. Thank you in advance for your assistance!
Ford Bronco Trouble Upgrading My Bronco with Procal4 - Need Help! 1694656008082
Ford Bronco Trouble Upgrading My Bronco with Procal4 - Need Help! c5ecb24bb8c21f5a2d82c2ceb79b2a5
OtisFE
Otis
Palm Coast FL
2022 Bronco OBX
Did you enter the voucher number on the Ford Performance website first?
kodiakisland
Arkansas
Restart computer after software install?
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
is the ProCal Tune approved for your area?
(the initial post was in chinese)
brockbrock
brock
raptor
bronco
Thank you for your reply. I believe it's possible. I am in China, but even after connecting it to the computer, it still doesn't respond to any actions
Ford Bronco Trouble Upgrading My Bronco with Procal4 - Need Help! 1694660547521
brockbrock
brock
raptor
bronco
Thank you for your response. I have already tried doing this
Lcubed
l
UsA
does your vehicle have a VIN starting with 1,2 or 4?
i suspect the tune is geolocked and require a 50 states US location or Canada.
or it could be blocked by the great firewall
brockbrock
brock
raptor
bronco
Yes, the VIN starts with 1
brockbrock
brock
raptor
bronco
i suspect the tune is geolocked and require a 50 states US location.
Lcubed
l
UsA
since the bronco is not officially for sale in china (yet),
i'm guessing the tune is calling home and getting a null response
brockbrock
brock
raptor
bronco
Thank you for your response. I agree with what you said; it should be possible to connect it to my Bronco. However, some functions seem to be unavailable. I changed my gear ratio to 4.7, and it appears that the speedometer correction feature should work, but my vehicle is still in the modification process and hasn't been tested yet. I wanted to ask if, after changing the gear ratio, this device needs to remain connected to the vehicle at all times while driving, or if it can be disconnected?
Additionally, I'd like to ask for the tire data for 37-inch tires. Thank you in advance!
Ford Bronco Trouble Upgrading My Bronco with Procal4 - Need Help! 343c5d941da85694d59c8bbc9729972
Lcubed
l
UsA
it can be removed. AWD will probably need to be relearned after the
gearing and tyre size change.
Big Pony
Subaru Ascent LTD '20
Questions:
I had the same issue. Tried 3 different Windows based laptops and got the same error. After the 3rd laptop, I realized it was NOT the PC having issues. I solved the problem by “brute force”, relentlessly clicking on the “try again” button on the pop up and eventually forcing the update push to Ford’s server. After that, installing it on the truck was flawless. Hope that helps.
smelly
Massachusetts
2022 2DR Black Diamond 7MT
Sounds silly - but try a different USB cable or a different port on your computer. Cheap USB cables can sometimes cause issues
