Tricky Dick's Dirty Bronco
Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
So how much clearance did you gain on the gas tank? I find that's the best part of my lift. I'm dragging that tank over far less stuff now.
I would say a solid 3" once the 37s are on.
kodiakisland
Arkansas
This is where I am with 35s. Will eventually go to 37s to get another inch.
Tricky Dick
Dick
PNW
Tricky Dick
Dick
PNW
I got two Territories dismounted last night, so my weekend project will be tightening beadlock bolts. I need to snap a pic, but the 37 grew 2" when mounted because it's a bit more pinched on the Sasquatched wheel than is ideal.
I have an alignment appointment this afternoon as well.
LockedBronco
Frank
PA
1972 Bronco
What is the width and how much air do you have in them?
Tricky Dick
Dick
PNW
LockedBronco
Frank
PA
1972 Bronco
What is the height now?
Tricky Dick
Dick
PNW
Right at 37 on the nose with no weight on it.
Alignment done. Feels a little twitchier now maybe. At first they told me they couldn‘t adjust the toe because they couldn't loosen my "tie rod extensions" even with a cheater bar. I assured him they were just jam nuts and I had only got them hand tight. He asked if I would loosen them so they wouldn't be liable for breaking them and I said sure, just wanted it done. I think he was going the wrong direction because it broke easily with just a combination wrench. 🤷
Ford Bronco Tricky Dick's Dirty Bronco PXL_20230217_230755360~2
Tricky Dick
Dick
PNW
I drove around a bit more tonight and steering is definitely a little twitchier. IDK if it's the toe or what because it does show in spec.
But I'm digging the stiffer springs, it corners more flatly now and brake dive is reduced. So far I would definitely recommend bumping up to 4dr and/or V6 spring if you have a 2dr or L4, even if it's not paired with Icons.
My Warn care package showed up today so time to get the winch finished up tomorrow.
dgorsett
colorado
F250, Mustang, Explorer
Mine with just a 1.5" Bilstein 5100 lift drove straight as a string and handled better than ever. It passed my hillbilly alignment, a carpenters level. So I have not been to the alignment shop yet. Don't really trust someone who may not understand righty tightly. (In fairness I struggled with a left hand thread on Razor tierod a while back) I'm putting some serious miles on it next week so we'll see.
Tricky Dick
Dick
PNW
I kind of feel that way too, but these modern techs are better at running computers than wrenches so I feel good about the print out.
As you can see my alignment wasn't even that far out just eyeballing everything. I had loosened every bolt so everything had moved too.
dgorsett
colorado
Yeah I noticed how close to spec you were, made me feel better
LockedBronco
Frank
PA
1972 Bronco
"twitchier now " ?
Just remember that when you put on the swampers and then are worn down like dollar store eraser (which is now $1.25) print out good.
New/modern techs are a joke.
LockedBronco
Frank
PA
1972 Bronco
Are you kidding me!!!!!
Tricky Dick
Dick
PNW
"twitchier now " ?
Hard to explain. Feels like I need to make more steering corrections and smaller movements over correct more.
Status
