Transmission Torque Capacity
Delasangre
Oregon City
2021 Ranger Lariat Tremor
So I was reading another post;
You read that here, where someone made it up. The tranny is rated at 406 lb-ft.
I had a ten speed, when I was 10. I'm a big boy now, if I want to drive a golf cart I'll go golfing.
If this rating is true that really concerns me, the 2.3 with a tune makes 370 Ft-lbs. I see broken transmissions in the future.
If I am looking at the correct info the 10-speed is rated for at least 650 Ft-lbs?
Can anyone expand upon this, because I was 100% sold on the 2.3 with manual because I could tune it later if I want more power but if the tune maxes out the manual and possibly requires a clutch at minimum then I may be going back to the 2.7 with 10-speed...
EDIT: according to this its actually 442 Ft-lbs, which is better, just a kinda lower threshold I would have liked.
https://www.bronco6g.com/forum/thre...h-low-crawler-gear-revealed-in-document.1114/
  • Like
Reactions: Tre
Felix808
SRV CA
You Sir have discovered why the manual is not offered with the 2.7 that is asked so often around here. ;)
DrewBronc21
New York
2020 Subaru STi, 2024 M2
The motor is only rated to 270 HP/310 Tq on the 2.3 and 310/400 on the 2.7 and we’re willing to push those well beyond what the factory intended so why not the transmission? Will the transmission suddenly explode if you cross that 400 torque #? Nobody knows but we’re going to find out! The 10 speed isn’t without its controversy either
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
if you go to the source, getrag website, it mentions the 400 lbs torque rating (I would be comfortable going right up against that, that’s what it was designed to handle all day). It also mentions that it can be upgradable for higher torque applications. I’ll dig around and see if I can post a link.
Itchysquatch
Luke
Vermont
Delasangre
Oregon City
https://www.getrag-ford.com/files/theme/downloads/6MTI550_Manual_Inline_Transmission.pdf
Scalable to 800nm which is roughly 600 foot pounds (same as the 10 speed auto FYI).
I’ll be getting the manual, and a tune...
I’ll let you know if I break it.... I’m not too worried.
I think I will be right there with you, I wonder if we will smoke the clutch with a tune. On the VW GTI if you have the manual and do a tune you HAVE to install a better clutch. Curious what the Bronco clutch can take.
Itchysquatch
Luke
Vermont
Hmm, I “tuned” my 4runner (added a supercharger), and didn’t have do anything to my clutch... wasn’t doing any street racing with it though. I guess time will tell. I’m guessing we’ll be ok though.
MaverickMan
Shane
This is what im planning. Hope i do frag it out in 5 or 6 years ofheavy abuse, so i can sell the 2.3 to a mustang or ranger guy take a junkyard 7.3 and HD 7spd out of a heavy duty truck or whatever that combo comes in and swap em. i wonder if at that time i will be the last big block swap ever?:unsure:
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
The 2.3 has been pushed much higher than the stats in the Bronco for other applications. The Focus RS was tuned for 345/350 and there was a non production car that pushed it to 395/369.
https://en.wikipedia.org/wiki/Ford_EcoBoost_engine#2.3_L
Personally I think Ford undertuned the 2.3 to account for harsh off-road environments. Also probably to keep it to regular fuel. But there's plenty of headroom there.
Apples
Nick
Frankly, if you're looking to push the engine/tranny past 400 ft lbs, you're probably into the realm where you're swapping in aftermarket parts anyway. You're going to want headers, exhaust, and an aftermarket clutch to maximize the power potential and handle all that torque effectively.
DrewBronc21
New York
I think I would be good with this for a while 306 whp/379 wtq with no Mods other than a tune on a Ranger....keeps it right against the transmission torque specs.
Ford Bronco Transmission Torque Capacity BD68C0EC-540E-40BE-A072-9385152F2CE4
DrewBronc21
New York
RockEye
Jason
Atlanta, GA
2004 Subaru WRX STI, 2DR Badlands Reservation
That graph looks like death quiver.
I'm actually more concerned about axles and such more than the transmissions once people start adding more power.
DrewBronc21
New York
how about Cobb? Instant torque axle twister. I’m not too worried at all because I dont beat on my cars.
Ford Bronco Transmission Torque Capacity BDEA09EA-C041-457D-8651-662B3D455390
