Transmission issues
Theblobishere92
Ian
Los Angeles
Bronco Base
Hi everyone.. I picked up my Bronco 2.7L 4 door Base on June 2022. I have 10,800 miles on it.
Let me preface this, I'm no car expert.
About 2 months ago I started noticing my Bronco lurching and clunking when going from park to reverse when the engine was cold. Every single day when I start the truck for the first time in the morning and put it in reverse, it does this lurch/jump and a clunk noise. The closest thing I can compare it to is when you're parked on a hill and you shift gears -- you get that clunk and a lurch.
Other things I've noticed, maybe because of my heightened awareness, when I'm breaking from going 35-40 miles an hour, as the transmission shifts down sometimes it clunks or shifts weirdly, not as intensely as when I start it in the morning and put it in reverse. This is fairly random and rare, but it does happen.
I've been in the process of moving ~80 miles across the state, but I did take the truck into the dealer. Of course it worked seamlessly when I had the technician with me. He said they would need the truck for 2-3 days to check it out. Unfortunately because I was moving, I couldn't commit the Bronco for that long. I'm now working on getting it into a dealership near my new home.
I'm curious if something I could have done could have caused this? I haven't done any intense off roading, mainly beginner trails. I haven't towed anything either..
Does anyone have any idea what causes this to happen?
PWillette
Parrie
Maine
Probably not the cause but did you check the fluid level and fluid condition?
Theblobishere92
Theblobishere92
Ian
Los Angeles
Bronco Base
Yes I did, the dealership did an oil change for me and checked transmission fluids and everything checked out
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Ian. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Ducati1098
Accelerated main control break in followed by clearing the adaptive transmission learning. I always have very good luck with this curing most intermittent weird shifts with 10 speeds.
Ask the dealership about SSM 51531
Theblobishere92
Theblobishere92
Ian
Los Angeles
Bronco Base
I’m not sure what any of this means, but I will show the dealership your message! Hopefully this is covered under the warranty.
Theblobishere92
Theblobishere92
Ian
Los Angeles
Bronco Base
Please keep us updated. I have noticed that exact same issue with my Bronco. Very curious about what @Ford has to tell you.
Hey Chris, will do. I reached out to Ford via DM about 2 hours ago with my VIN and dealership.
Ducati1098
No reason it shouldn’t be covered under warranty.
Here you go, this should help.
Ford Bronco Transmission issues IMG_1087
Ford Motor Company
Dearborn
Hello, Chris! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this transmission concern. Thanks!
Theblobishere92
Theblobishere92
Ian
Los Angeles
Bronco Base
Generally, it seems to be shifting much smoother. I think I had gotten used to hearing it shift throughout normal operation., now it's smooth as butter. I haven't had any down shift issues while driving at higher speeds then coming to a stop.
I won't be able to tell if there are issues going from park to reverse until the engine is cold tomorrow morning.
