TrailRax RTT compatibility
Aguas
Nate
Seattle
Bronco, F150
@TrailRax Can you give the dimensions of the Trailrax rack? I haven’t been able to find the length and width, only the height.
We’re trying to determine if we can fit the FSR Evolution V2 Long RTT. My wife and I are both fairly tall so a larger tent would be ideal.
We’ve reviewed the TrailRax Accessory Guide for compatibility but wanted to know if anyone else has successfully mounted the larger tent. Would love to see what y’all have done!
Chief Dan
Dan
Federal Way, WA
Subaru Forester
Looks like it is about 44 1/2" wide inside the rails - which is where the mountings will go - and 94 1/2" long, however the rear end is 'open' so things could go longer, but will eventually interfere with your glass coming up in the back
Ford Bronco TrailRax RTT compatibility 20230625_141111
Ford Bronco TrailRax RTT compatibility 20230706_180043
Ford Bronco TrailRax RTT compatibility 20230706_175909
Ford Bronco TrailRax RTT compatibility 20230706_175801
Aguas
Aguas
Nate
Seattle
Bronco, F150
Thank you so much for getting those measurements!
I think it may hang over the rails slightly width wise and the length sounds like it will definitely still fit. We have 2 dogs and ourselves so we were looking for as much space as possible!
Here are the dimensions from their site:
Ford Bronco TrailRax RTT compatibility IMG_3339
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
How many doors on your Bronco?
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
Ford Bronco Badlands
Is it Mini 3.0? Does it require any additional mounts or just straight to the rack with included clamps?
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
The Ikamper Skycamp 3.0, while large, has been a great option for customers with our rack. It basically takes up the entire length of the rack but offers plenty of sleeping area. Width on the tent folded is 55" so it will fit much nicer on there than a 60" width.
Do keep in mind static load rating when loading the rack at camp.
