Trailer Brake Module Fault
akinG6OB
Aneil
Virginia Beach
2022 Bronco
Over the last three weeks I started getting a random "trailer brake module fault" pop up on my dash. I took it to the dealer last week and not only did they not have a solution, now I also get a "trailer brake fault" pop up intermittently with the module fault repeatedly while driving the vehicle. Can anyone provide any insight to the problem and how to fix it? It has gotten so bad that I just don't drive it.
I call the dealer (Beach Ford) everyday to see if they have a fix and I think they are ghosting me because no one will answer or return my calls.
akinG6OB
akinG6OB
Aneil
Virginia Beach
2022 Bronco
Here is a brief video of the fault notices.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning. Would you privately message us with your VIN and the location of your Ford dealer so I can look into this trailer brake message concern on my end? Thank you!
mini4mw
W
Atlanta
Tundra
1) Do you have factory 7pin towing package?
2) When it comes up are you towing anything, doesn't sound like it..
3) Do you have a brake controller installed, what model
4) have you disconnected the negative terminal of the battery for a period of time to let the car 'reset'? The Bronco seems like an older Windows computer that needs to be rebooted once in a a while
5) if it keeps happening, it may be related to the F150 TSB.
https://www.f150forum.com/f129/trailer-brake-module-fault-501819/
https://www.carcomplaints.com/Ford/F-150/2021/tsbs/tsb-21b08-s1.shtml
If you google that error there are lots of similar threads for the F150 which probably shares the same components. One thing they can do is reflash/program that module with some IDS software/machine. google gives more info on it. If reprogramming doesn't do it, could be short/loose wire in the 7/4 pin plug.
akinG6OB
akinG6OB
Aneil
Virginia Beach
2022 Bronco
Thank you for your reply.
1)yes,
2)no
3)no, I have not had one installed.
4)I have not. I saw this suggested fix on a blog but was hesitant that it might mess up other computers. But, I will try it.
Thanks again.
mini4mw
W
Atlanta
Tundra
i'd try the reset, if that doesn't work get the dealer to re-flash/program the module, if that doesn't work sounds like a module failure or possibly issue with 7/4 pin connector. The reprogram may also error out showing a faulty unit. If the dealer has no ideas, they can at least try that..
akinG6OB
akinG6OB
Aneil
Virginia Beach
2022 Bronco
Thank you for the help. I disconnected the negative terminal on the battery last night to restart the computer and the fault is no longer persistently showing up but seems to pop up when I let my foot off the brake after coming to a complete stop and then goes away on its own almost right away.
I will give the other options a try. Ford actually opened a case on the issue from this thread and direct communications on bronco6g so there is hope it will get resolved.
Thanks again,
Aneil
mini4mw
W
Atlanta
Tundra
Thanks for the update. That is a tough gremlin. Sounds like it could be a short, bad ground or the module. I'd double check no moisture on the 4/7 pin socket (open the flaps and make sure the pins are dry) and wiggle the back of the connector and lightly pull on the cord coming out to see if makes any changes (loose wires somewhere). If no changes, its probably something under the plastic (lose wire) or the module and I'd let Ford figure it out (unfortunately). If you wanted to get into it, I'd follow/find where the ground goes from the 4/7 and make sure its tight and clean.
DaGuzer
Guze
Encinitas
‘21 Bronco OBX
I have the same issue with mine. Took it to Encinitas Ford and awaiting the replacement module that I’m told should fix it. Been waiting three months now. Getting annoyed with the dash notice every time I start it.
The module is in a terrible spot IMO, above rear driver tire inside behind the plastic trim pieces. I think moisture may have gotten back there. Designers should never have put it in that location, especially with a soft top
akinG6OB
akinG6OB
Aneil
Virginia Beach
2022 Bronco
Sorry to hear it. At times the constant chime was maddening. My replacement module came in on 12/19 and had it promptly replaced. No more faults and chimes. I hope your Ford dealer can get their hands on your module.
brewsterdabronco
San Marcos, TX
Two Door 6G
I’m having the same issue too. Showed up about two months ago with other electrical notifications then again yesterday while driving. Received a notification informing me to shut the vehicle down. Pulled into a gas station and heard a relay in the back driver side throwing numerous times. I’ll disconnect neutral and see what happens.
Roc_Cero8
Carlos
Springfield, VA
2022 Ford Bronco Wildtrak
I am having this same issue and it is driving me insane. Anyword on how to fix this. I have already scheduled an appointment at my local Ford but would like to see if there is a way to disable it until it gets serviced. Any help would be greatly appreciated.
@Ford please find a fix for this because it is very distracting and could potentially cause an accident. It makes the instrument panel hard to read speed and RPMs with the fault taking up the whole screen and constantly popping up.
da_jokker
Jeep Wrangler JKUR
When I installed my brake controller, there is a plug that goes into the end of the wire harness that you have to remove in order to plug the actual brake controller into.
This isn't a dust cover and I don't know what it does but it does remind me of somthing that may have some sort of wire jumper function.
My point, maybe try unplugging it and either leave it out or clean it and make sure it is seated correctly.
You can see what I'm talking about in various Bronco Redarc Brake Controller install videos on YouTube..bit basically it is a plug just above the driver's side of the center console under the dash. Totally accessible when you just look under there.
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
I just got this for the first time today. I pulled over unplugged my seven pin connector and plugged it back in. The errors went away. Time will tell if that’s a long-term fix. I suspect just a bad connection in the plug.
Edit: no dice on it being a long-term fix. It did make the error go away for a few hours. But it came back. Even worse, now after I disconnect a trailer my blinkers are flashing rapidly. I’ll try the battery disconnect and see if that helps.
EAD
Eugene
Elizabethon
2024 Bronco
Does anyone know the P/N for just the Module Trailer Brake I do need the whole kit
